Waf and Ada?
    Sebastian Huber
    Fri Oct  4 06:25:37 UTC 2019
On 04/10/2019 08:08, Chris Johns wrote:
> On 4/10/19 3:17 pm, Sebastian Huber wrote:
>> On 03/10/2019 04:38, Chris Johns wrote:
>>> On 2/10/19 9:21 pm, Sebastian Huber wrote:
>>>> the waf build prototype contains no examples for building Ada objects, libraries
>>>> and executables.
>>>> https://git.rtems.org/amar/waf-old.git/
>>>> Searching the internet revealed also nothing. It would be great to have an
>>>> example for building an Ada test executable (mix of C and Ada files).
>>> The best way to handle this is to create a tool for Ada ...
>>> https://gitlab.com/ita1024/waf/tree/master/waflib/Tools
>>> https://github.com/BNLIF/waf-tools
>>> I am sure Thomas would be happy to accept such a tool. He is on IRC #rtems as
>>> ita.
>> Thanks for the hint. So, the Ada support for RTEMS first requires Ada support
>> for waf. I will probably work on this with a low priority.
> It is not an absolute requirement however adding a tool upstream makes the long
> term maintenance simpler for RTEMS.
Yes, this is definitely the way to go.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
