Testing the interrupt extension API?
Sebastian Huber
Fri Oct 4 06:34:08 UTC 2019
On 02/10/2019 19:44, Gedare Bloom wrote:
> On Wed, Oct 2, 2019 at 1:28 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Hello,
>> the interrupt extension API implementation is already quite complex and
>> not covered by the test suite:
>> https://git.rtems.org/rtems/tree/bsps/shared/irq
>> In order to write generic tests for this we have to know which interrupt
>> vector can be controlled by software. One approach would be to add an
>> rtems_interrupt_get_capabilities() function:
>> * @brief A bit field indicating interrupt capabilities.
> I don't care for the term 'capabilities' here, maybe 'attributes' is
> OK? Can we overload these fields onto rtems_attribute?
Yes, attributes is better.
>> typedef struct {
>> * @brief Is set, if the interrupt can be enabled through
>> * rtems_interrupt_vector_enable(), otherwise cleared.
>> unsigned int can_enable : 1;
> disabled / disable()
>> unsigned int can_disable : 1;
> Curious: are there vectors that can be enabled but not disabled (or vice versa)?
Probably not.
>> * @brief Is set, if the interrupt can be raised through
>> * rtems_interrupt_raise(), otherwise cleared.
>> unsigned int can_raise : 1;
>> * @brief Is set, if the interrupt can be cleared through
>> * rtems_interrupt_clear(), otherwise cleared.
>> unsigned int can_clear : 1;
>> * @brief Is set, if the interrupt supports a setting of its priority
>> through
>> * rtems_interrupt_set_priority(), otherwise cleared.
>> unsigned int can_set_priority : 1;
>> * @brief Is set, if the interrupt supports a setting of its processor
>> * affinity through rtems_interrupt_set_affinity(), otherwise cleared.
>> unsigned int can_set_affinity : 1;
>> * @brief Is set, if the interrupt has a pending state which can be
>> obtained
>> * through rtems_interrupt_is_pending(), otherwise cleared.
>> unsigned int has_pending_state : 1;
> This is strange wording, because it implies a currently pending state.
> Maybe, "can_be_pending"?
>> * @brief Is set, if the interrupt has an active state which can be
>> obtained
>> * through rtems_interrupt_is_active(), otherwise cleared.
>> unsigned int has_active_state : 1;
> ditto: can_be_active?
Yes, sounds good.
>> * @brief Is set, if the interrupt is connected to a peripheral,
>> otherwise
>> * cleared.
>> unsigned int has_peripheral : 1;
> I guess this one is more a statement of fact.
What do you mean by this?
We have to know if an interrupt is connected to a peripheral function.
Since these interrupts must not be used by a generic test. The generic
test has no idea in which state a peripheral is.
>> * @brief Is set, if the interrupt must be raised through
>> * rtems_interrupt_raise_on(), otherwise cleared.
>> unsigned int needs_target : 1;
>> * @brief Is set, if the interrupt is triggered by a raising signal edge,
>> * otherwise cleared.
>> unsigned int is_raising_edge_triggered : 1;
>> * @brief Is set, if the interrupt is triggered by a falling signal edge,
>> unsigned int is_falling_edge_triggered : 1;
>> * @brief Is set, if the interrupt is triggered by a low signal level,
>> unsigned int is_low_level_triggered : 1;
>> * @brief Is set, if the interrupt is triggered by a high signal level,
>> unsigned int is_high_level_triggered : 1;
>> } rtems_interrupt_capabilities;
>> * @brief Gets the capabilities of the specified interrupt.
>> * @retval RTEMS_SUCCESSFUL Successful operation.
>> * @retval RTEMS_INVALID_ID The specified vector number is invalid.
>> rtems_status_code rtems_interrupt_get_capabilities(
>> rtems_vector_number vector,
>> rtems_interrupt_capabilities *capabilities
>> Interrupts with cap.can_raise set and cap.has_peripheral cleared can be
>> safely software controlled and used for tests.
> Why not just have an "is_software_triggered"?
As a replacement for has_peripheral?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
