[PATCH 3/3] linkersets: Avoid use of zero-length array
Fri Oct 4 08:00:00 UTC 2019
Use RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION() instead.
 cpukit/include/rtems/linkersets.h | 34 ++++++++++++++++++++++------------
 1 file changed, 22 insertions(+), 12 deletions(-)
diff --git a/cpukit/include/rtems/linkersets.h b/cpukit/include/rtems/linkersets.h
index bad046999c..4a23d7a696 100644
--- a/cpukit/include/rtems/linkersets.h
+++ b/cpukit/include/rtems/linkersets.h
@@ -28,14 +28,19 @@ extern "C" {
   _Linker_set_##set##_end
 #define RTEMS_LINKER_ROSET_DECLARE( set, type ) \
-  extern type const RTEMS_LINKER_SET_BEGIN( set )[0]; \
-  extern type const RTEMS_LINKER_SET_END( set )[0]
+  extern type const RTEMS_LINKER_SET_BEGIN( set )[]; \
+  extern type const RTEMS_LINKER_SET_END( set )[]
 #define RTEMS_LINKER_ROSET( set, type ) \
-  type const RTEMS_LINKER_SET_BEGIN( set )[0] \
-  RTEMS_SECTION( ".rtemsroset." #set ".begin" ) RTEMS_USED; \
-  type const RTEMS_LINKER_SET_END( set )[0] \
-  RTEMS_SECTION( ".rtemsroset." #set ".end" ) RTEMS_USED
+  RTEMS_LINKER_ROSET_DECLARE( set, type ); \
+  RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION( \
+    RTEMS_LINKER_SET_BEGIN( set ), \
+    ".rtemsroset." #set ".begin" \
+    RTEMS_LINKER_SET_END( set ), \
+    ".rtemsroset." #set ".end" \
 #define RTEMS_LINKER_ROSET_ITEM_DECLARE( set, type, item ) \
   extern type const _Linker_set_##set##_##item
@@ -59,14 +64,19 @@ extern "C" {
   RTEMS_SECTION( ".rtemsroset." #set ".content" )
 #define RTEMS_LINKER_RWSET_DECLARE( set, type ) \
-  extern type RTEMS_LINKER_SET_BEGIN( set )[0]; \
-  extern type RTEMS_LINKER_SET_END( set )[0]
+  extern type RTEMS_LINKER_SET_BEGIN( set )[]; \
+  extern type RTEMS_LINKER_SET_END( set )[]
 #define RTEMS_LINKER_RWSET( set, type ) \
-  type RTEMS_LINKER_SET_BEGIN( set )[0] \
-  RTEMS_SECTION( ".rtemsrwset." #set ".begin" ) RTEMS_USED; \
-  type RTEMS_LINKER_SET_END( set )[0] \
-  RTEMS_SECTION( ".rtemsrwset." #set ".end" ) RTEMS_USED
+  RTEMS_LINKER_RWSET_DECLARE( set, type ); \
+    ".rtemsrwset." #set ".begin" \
+    ".rtemsrwset." #set ".end" \
 #define RTEMS_LINKER_RWSET_ITEM_DECLARE( set, type, item ) \
   extern type _Linker_set_##set##_##item
2.16.4
