[PATCH 2/2] termios: Add Capability to Generate SIGINTR and SIGQUIT
Mon Oct 7 21:40:20 UTC 2019
This patch adds the ability for termios to send SIGINTR on receipt
of VINTR and SIGQUIT for VKILL and return -1/EINTR from read() on
a termios channel. Importantly, this patch does not alter the default
behavior or force POSIX signal code in just because termios is used.
The application must explicitly enable the POSIX behavior of generating
a signal upon receipt of these characters. This is discussed in the
POSIX standard:
   https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/V1_chap11.html
Closes #3800.
 cpukit/Makefile.am                                 |   1 +
 cpukit/include/rtems/libio.h                       | 118 ++++++++++-
 cpukit/include/rtems/rtems/status.h                |   9 +-
 cpukit/libcsupport/src/termios.c                   | 225 +++++++++++++++++----
 .../libcsupport/src/termios_posix_isig_handler.c   |  39 ++++
 cpukit/rtems/src/statustext.c                      |   1 +
 cpukit/rtems/src/statustoerrno.c                   |   1 +
 testsuites/libtests/Makefile.am                    |  22 +-
 testsuites/libtests/configure.ac                   |   2 +
 9 files changed, 371 insertions(+), 47 deletions(-)
 create mode 100644 cpukit/libcsupport/src/termios_posix_isig_handler.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 01ee409..7698fe5 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -250,6 +250,7 @@ librtemscpu_a_SOURCES += libcsupport/src/termios_baudtable.c
 librtemscpu_a_SOURCES += libcsupport/src/termios.c
 librtemscpu_a_SOURCES += libcsupport/src/termiosinitialize.c
 librtemscpu_a_SOURCES += libcsupport/src/termios_num2baud.c
+librtemscpu_a_SOURCES += libcsupport/src/termios_posix_isig_handler.c
 librtemscpu_a_SOURCES += libcsupport/src/termios_setbestbaud.c
 librtemscpu_a_SOURCES += libcsupport/src/termios_setinitialbaud.c
 librtemscpu_a_SOURCES += libcsupport/src/__times.c
diff --git a/cpukit/include/rtems/libio.h b/cpukit/include/rtems/libio.h
index f3b0f2c..a665bd6 100644
--- a/cpukit/include/rtems/libio.h
+++ b/cpukit/include/rtems/libio.h
@@ -1880,6 +1880,8 @@ extern const rtems_filesystem_mount_configuration
+struct rtems_termios_tty;
 typedef struct rtems_termios_callbacks {
   int    (*firstOpen)(int major, int minor, void *arg);
   int    (*lastClose)(int major, int minor, void *arg);
@@ -1907,6 +1909,116 @@ rtems_status_code rtems_termios_bufsize (
   size_t raw_output    /* raw output buffer size */
+ * @brief Type returned by all input processing (isig) methods
+typedef enum {
+   * This indicates that the input character was processed
+   * and possibly placed into the buffer.
+  RTEMS_TERMIOS_ISIG_WAS_PROCESSED,
+   * This indicates that the input character was not processed and
+   * subsequent processing is required.
+  RTEMS_TERMIOS_ISIG_WAS_NOT_PROCESSED,
+   * This indicates that the character was processed and determined
+   * to be one that requires a signal to be raised (e.g. VINTR or
+   * VKILL). The tty must be in the right termios mode for this to
+   * occur. There is no further processing of this character required and
+   * the pending read() operation should be interrupted.
+  RTEMS_TERMIOS_ISIG_INTERRUPT_READ
+} rtems_termios_isig_status_code;
+ * @brief Type for ISIG (VINTR/VKILL) handler
+ * This type defines the interface to a method which will process
+ * VKILL and VINTR characters. The user can register a handler to
+ * override the default behavior which is to take no special action
+ * on these characters. The POSIX required behavior is to
+ * generate a SIGINTR or SIGQUIT signal. This behavior is implemented if
+ * the user registers the @ref rtems_termios_posix_isig_handler().
+ * @param c     character that was input
+ * @param tty   termios structure pointer for this input tty
+ * @return The value returned is according to that documented
+ *         for @ref rtems_termios_isig_status_code.
+typedef rtems_termios_isig_status_code (*rtems_termios_isig_handler)(
+  unsigned char             c,
+  struct rtems_termios_tty *tty
+ * @brief Default handler for ISIG (VINTR/VKILL)
+ * This handler is installed by default by termios. It performs
+ * no actions on receiving the VINTR and VKILL characters. This is
+ * not POSIX conformant behavior but is the historical RTEMS behavior
+ * and avoid any default dependency on signal processing code.
+ * The installed ISIG handler is only invoked if the character is
+ * (VKILL or VINTR) and ISIG is enabled. Thus the handler need only
+ * check the character and perform the appropriate action.
+ *         for all methods adhering to @ref rtems_termios_isig_handler.
+rtems_termios_isig_status_code rtems_termios_default_isig_handler(
+  unsigned char             c,
+ * @brief POSIX handler for ISIG (VINTR/VKILL)
+ * This handler is installed by the used to obtain POSIX behavior
+ * upon receiving the VINTR and VKILL characters.  The POSIX required
+ * behavior is to generate a SIGINTR or SIGQUIT signal if ISIG is enabled.
+rtems_termios_isig_status_code rtems_termios_posix_isig_handler(
+  unsigned char             c,
+ * @brief Register handler for ISIG (VINTR/VKILL)
+ * This method is invoked to install an ISIG handler. This may be used
+ * to install @ref rtems_termios_posix_isig_handler() to obtain POSIX
+ * behavior or a custom handler. The handler
+ * @ref rtems_termios_default_isig_handler() is installed by default.
+ * @param handler entry point of the new ISIG handler
+ * @return The integer returned is 0 to indicate success and a non-zero
+ *         value otherwise.
+int rtems_termios_register_isig_handler(
+  rtems_termios_isig_handler handler
+int rtems_termios_enqueue_raw_characters(
+  void *ttyp,
+  const char *buf,
+  int   len
 rtems_status_code rtems_termios_open (
   rtems_device_major_number      major,
   rtems_device_minor_number      minor,
@@ -1930,12 +2042,6 @@ rtems_status_code rtems_termios_ioctl(
   void *arg
-int rtems_termios_enqueue_raw_characters(
-  void *ttyp,
-  const char *buf,
-  int   len
 int rtems_termios_dequeue_characters(
   void *ttyp,
   int   len
diff --git a/cpukit/include/rtems/rtems/status.h b/cpukit/include/rtems/rtems/status.h
index 88ae576..7310fe9 100644
--- a/cpukit/include/rtems/rtems/status.h
+++ b/cpukit/include/rtems/rtems/status.h
@@ -167,6 +167,12 @@ typedef enum {
   RTEMS_IO_ERROR                 = 27,
+   *  This is the status used internally to indicate a blocking device
+   *  driver call has been interrupted and should be reflected to the
+   *  called as an INTERRUPTED.
+  RTEMS_INTERRUPTED              = 28,
    *  This is the status is used internally to RTEMS when performing
    *  operations on behalf of remote tasks.  This is referred to as
    *  proxying operations and this status indicates that the operation
@@ -174,7 +180,7 @@ typedef enum {
    *  @note This status will @b NOT be returned to the user.
-  RTEMS_PROXY_BLOCKING           = 28
+  RTEMS_PROXY_BLOCKING           = 29
 } rtems_status_code;
@@ -235,6 +241,7 @@ RTEMS_INLINE_ROUTINE bool rtems_are_statuses_equal(
  *  @retval ENODEV RTEMS_UNSATISFIED
  *  @retval ENOSYS RTEMS_NOT_IMPLEMENTED, RTEMS_NOT_CONFIGURED
  *  @retval ENOMEM RTEMS_NO_MEMORY
+ *  @retval EINTR RTEMS_INTERRUPTED
 int rtems_status_code_to_errno(rtems_status_code sc);
diff --git a/cpukit/libcsupport/src/termios.c b/cpukit/libcsupport/src/termios.c
index 0fc9de45..34c6b7c 100644
--- a/cpukit/libcsupport/src/termios.c
+++ b/cpukit/libcsupport/src/termios.c
@@ -1301,76 +1301,169 @@ iprocEarly (unsigned char c, rtems_termios_tty *tty)
+ * This points to the currently registered method to perform
+ * ISIG processing of VKILL and VQUIT characters.
+static rtems_termios_isig_handler termios_isig_handler =
+   rtems_termios_default_isig_handler;
+ * This is the default method to process VKILL or VQUIT characters if
+ * ISIG processing is enabled. Note that it does nothing.
+  unsigned char c,
+  return RTEMS_TERMIOS_ISIG_WAS_NOT_PROCESSED;
+ * Register a method to process VKILL or VQUIT characters if
+  if (handler == NULL) {
+    return -1;
+  termios_isig_handler = handler;
+  return 0;
+ * @brief Type returned by all input processing (iproc) methods
+typedef enum {
+   * and the results were placed into the buffer.
+  RTEMS_TERMIOS_IPROC_IN_BUFFER,
+   * and the result did not go into the buffer.
+  RTEMS_TERMIOS_IPROC_WAS_PROCESSED,
+  RTEMS_TERMIOS_IPROC_WAS_NOT_PROCESSED,
+  RTEMS_TERMIOS_IPROC_INTERRUPT_READ
+} rtems_termios_iproc_status_code;
  * Process a single input character
-static int
+static rtems_termios_iproc_status_code
 iproc (unsigned char c, struct rtems_termios_tty *tty)
+   * If signals are enabled, then allow possibility of VINTR causing
+   * SIGINTR and VQUIT causing SIGQUIT. Invoke user provided isig handler.
+  if ((tty->termios.c_lflag & ISIG)) {
+    if ((c == tty->termios.c_cc[VINTR]) || (c == tty->termios.c_cc[VQUIT])) {
+      rtems_termios_isig_status_code rc;
+      rc = (*termios_isig_handler)(c, tty);
+      if (rc == RTEMS_TERMIOS_ISIG_INTERRUPT_READ) {
+         return RTEMS_TERMIOS_IPROC_INTERRUPT_READ;
+      if (rc == RTEMS_TERMIOS_ISIG_WAS_PROCESSED) {
+         return RTEMS_TERMIOS_IPROC_IN_BUFFER;
+      _Assert(rc == RTEMS_TERMIOS_ISIG_WAS_NOT_PROCESSED);
+   * Perform canonical character processing.
   if ((c != '\0') && (tty->termios.c_lflag & ICANON)) {
     if (c == tty->termios.c_cc[VERASE]) {
       erase (tty, 0);
-      return 0;
+      return RTEMS_TERMIOS_IPROC_WAS_PROCESSED;
     else if (c == tty->termios.c_cc[VKILL]) {
       erase (tty, 1);
-      return 0;
     else if (c == tty->termios.c_cc[VEOF]) {
-      return 1;
     } else if (c == '\n') {
       if (tty->termios.c_lflag & (ECHO | ECHONL))
         echo (c, tty);
       tty->cbuf[tty->ccount++] = c;
-      return 1;
     } else if ((c == tty->termios.c_cc[VEOL]) ||
                (c == tty->termios.c_cc[VEOL2])) {
       if (tty->termios.c_lflag & ECHO)
         echo (c, tty);
-      return 1;
+   * Perform non-canonical character processing.
    * FIXME: Should do IMAXBEL handling somehow
   if (tty->ccount < (CBUFSIZE-1)) {
       echo (c, tty);
-  return 0;
+  return RTEMS_TERMIOS_IPROC_WAS_NOT_PROCESSED;
  * Process input character, with semaphore.
-static int
 siproc (unsigned char c, struct rtems_termios_tty *tty)
-  int i;
+  rtems_termios_iproc_status_code rc;
    * Obtain output semaphore if character will be echoed
   if (tty->termios.c_lflag & (ECHO|ECHOE|ECHOK|ECHONL|ECHOPRT|ECHOCTL|ECHOKE)) {
     rtems_mutex_lock (&tty->osem);
-    i = iproc (c, tty);
+    rc = iproc (c, tty);
     rtems_mutex_unlock (&tty->osem);
   else {
-  return i;
+  return rc;
-static int
 siprocPoll (unsigned char c, rtems_termios_tty *tty)
   if (c == '\r' && (tty->termios.c_iflag & IGNCR) != 0) {
-    return 0;
+   * iprocEarly is done at the interrupt level for interrupt driven
+   * devices so we need to perform those actions before processing
+   * the character.
   c = iprocEarly (c, tty);
   return siproc (c, tty);
@@ -1378,10 +1471,12 @@ siprocPoll (unsigned char c, rtems_termios_tty *tty)
  * Fill the input buffer by polling the device
-static void
 fillBufferPoll (struct rtems_termios_tty *tty)
-  int n;
+  int                             n;
+  rtems_termios_iproc_status_code retval = RTEMS_TERMIOS_IPROC_WAS_PROCESSED;
   if (tty->termios.c_lflag & ICANON) {
     for (;;) {
@@ -1389,8 +1484,14 @@ fillBufferPoll (struct rtems_termios_tty *tty)
       if (n < 0) {
         rtems_task_wake_after (1);
       } else {
-        if  (siprocPoll (n, tty))
+        rc = siprocPoll (n, tty);
+        if (rc == RTEMS_TERMIOS_IPROC_IN_BUFFER) {
+          break;
+        if (rc == RTEMS_TERMIOS_IPROC_INTERRUPT_READ) {
+          retval = RTEMS_TERMIOS_IPROC_INTERRUPT_READ;
           break;
   } else {
@@ -1417,7 +1518,11 @@ fillBufferPoll (struct rtems_termios_tty *tty)
       } else {
-        siprocPoll (n, tty);
+          break;
         if (tty->ccount >= tty->termios.c_cc[VMIN])
           break;
         if (tty->termios.c_cc[VMIN] && tty->termios.c_cc[VTIME])
@@ -1425,12 +1530,13 @@ fillBufferPoll (struct rtems_termios_tty *tty)
+  return retval;
  * Fill the input buffer from the raw input queue
-static void
 fillBufferQueue (struct rtems_termios_tty *tty)
   rtems_termios_device_context *ctx = tty->device_context;
@@ -1448,8 +1554,9 @@ fillBufferQueue (struct rtems_termios_tty *tty)
     while ((tty->rawInBuf.Head != tty->rawInBuf.Tail) &&
                        (tty->ccount < (CBUFSIZE-1))) {
-      unsigned char c;
-      unsigned int newHead;
+      unsigned char                    c;
+      unsigned int                     newHead;
       newHead = (tty->rawInBuf.Head + 1) % tty->rawInBuf.Size;
       c = tty->rawInBuf.theBuf[newHead];
@@ -1479,12 +1586,21 @@ fillBufferQueue (struct rtems_termios_tty *tty)
       /* continue processing new character */
-        if (siproc (c, tty)) {
-          /* In canonical mode, input is made available line by line */
-          return;
+        rc = siproc (c, tty);
+        /* If the read() should be interrupted, return */
+	/* In canonical mode, input is made available line by line */
       } else {
-        siproc (c, tty);
           wait = false;
@@ -1519,13 +1635,19 @@ fillBufferQueue (struct rtems_termios_tty *tty)
-static uint32_t
-rtems_termios_read_tty (struct rtems_termios_tty *tty, char *buffer,
-  uint32_t initial_count)
+static rtems_status_code
+rtems_termios_read_tty (
+  struct rtems_termios_tty *tty,
+  char                     *buffer,
+  uint32_t                  initial_count,
+  uint32_t                 *count_read
-  uint32_t count;
+  uint32_t                         count;
+  rtems_termios_iproc_status_code  rc = RTEMS_TERMIOS_IPROC_WAS_PROCESSED;
   count = initial_count;
@@ -1533,28 +1655,43 @@ rtems_termios_read_tty (struct rtems_termios_tty *tty, char *buffer,
     tty->cindex = tty->ccount = 0;
     tty->read_start_column = tty->column;
     if (tty->handler.poll_read != NULL && tty->handler.mode == TERMIOS_POLLED)
-      fillBufferPoll (tty);
+      rc = fillBufferPoll (tty);
     else
-      fillBufferQueue (tty);
+      rc = fillBufferQueue (tty);
+   * If there are characters in the buffer, then copy them to the caller.
   while (count && (tty->cindex < tty->ccount)) {
     *buffer++ = tty->cbuf[tty->cindex++];
     count--;
   tty->tty_rcvwakeup = false;
-  return initial_count - count;
+  *count_read = initial_count - count;
+   * fillBufferPoll and fillBufferQueue can indicate that the operation
+   * was interrupted. The isig handler can do nothing, have POSIX behavior
+   * and cause a signal, or a user defined action.
+    return RTEMS_INTERRUPTED;
+  return RTEMS_SUCCESSFUL;
 rtems_status_code
 rtems_termios_read (void *arg)
-  rtems_libio_rw_args_t *args = arg;
+  rtems_libio_rw_args_t    *args = arg;
   struct rtems_termios_tty *tty = args->iop->data1;
+  rtems_status_code         sc;
   rtems_mutex_lock (&tty->isem);
   if (rtems_termios_linesw[tty->t_line].l_read != NULL) {
-    rtems_status_code sc;
     sc = rtems_termios_linesw[tty->t_line].l_read(tty,args);
@@ -1562,9 +1699,14 @@ rtems_termios_read (void *arg)
     return sc;
-  args->bytes_moved = rtems_termios_read_tty (tty, args->buffer, args->count);
+  sc = rtems_termios_read_tty(
+    tty,
+    args->buffer,
+    args->count,
+    &args->bytes_moved
   rtems_mutex_unlock (&tty->isem);
-  return RTEMS_SUCCESSFUL;
+  return sc;
@@ -2022,7 +2164,8 @@ static ssize_t
 rtems_termios_imfs_read (rtems_libio_t *iop, void *buffer, size_t count)
   struct rtems_termios_tty *tty;
-  uint32_t bytes_moved;
+  uint32_t                  bytes_moved;
   tty = iop->data1;
@@ -2049,9 +2192,13 @@ rtems_termios_imfs_read (rtems_libio_t *iop, void *buffer, size_t count)
     return (ssize_t) args.bytes_moved;
-  bytes_moved = rtems_termios_read_tty (tty, buffer, count);
+  sc = rtems_termios_read_tty(tty, buffer, count, &bytes_moved);
+  if (sc != RTEMS_SUCCESSFUL) {
+     return rtems_status_code_to_errno (sc);
   return (ssize_t) bytes_moved;
 static ssize_t
diff --git a/cpukit/libcsupport/src/termios_posix_isig_handler.c b/cpukit/libcsupport/src/termios_posix_isig_handler.c
new file mode 100644
index 0000000..105e7f4
--- /dev/null
+++ b/cpukit/libcsupport/src/termios_posix_isig_handler.c
@@ -0,0 +1,39 @@
+ * @file
+ * TERMIOS POSIX behavior on INTR and QUIT characters
+ *  COPYRIGHT (c) 1989-2012,2019.
+ *  On-Line Applications Research Corporation (OAR).
+ *  SPDX-License-Identifier: BSD-2-Clause
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/libio.h>
+#include <rtems/termiostypes.h>
+#include <signal.h>
+  unsigned char             c,
+  if (c == tty->termios.c_cc[VINTR]) {
+    raise(SIGINT);
+    return RTEMS_TERMIOS_ISIG_INTERRUPT_READ;
+  if (c == tty->termios.c_cc[VQUIT]) {
+    raise(SIGQUIT);
diff --git a/cpukit/rtems/src/statustext.c b/cpukit/rtems/src/statustext.c
index f701ebd..2369794 100644
--- a/cpukit/rtems/src/statustext.c
+++ b/cpukit/rtems/src/statustext.c
@@ -53,6 +53,7 @@ static const char *const status_code_text[] = {
   "RTEMS_INTERNAL_ERROR",
   "RTEMS_NO_MEMORY",
   "RTEMS_IO_ERROR",
+  "RTEMS_INTERRUPTED",
   "RTEMS_PROXY_BLOCKING"
diff --git a/cpukit/rtems/src/statustoerrno.c b/cpukit/rtems/src/statustoerrno.c
index 8f34ff5..76a9e2c 100644
--- a/cpukit/rtems/src/statustoerrno.c
+++ b/cpukit/rtems/src/statustoerrno.c
@@ -45,6 +45,7 @@ static const int status_code_to_errno [RTEMS_STATUS_CODES_LAST + 1] = {
   [RTEMS_INTERNAL_ERROR]           = EIO,
   [RTEMS_NO_MEMORY]                = ENOMEM,
   [RTEMS_IO_ERROR]                 = EIO,
+  [RTEMS_INTERRUPTED]              = EINTR,
   [RTEMS_PROXY_BLOCKING]           = EIO
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index 1b80283..20a5a6f 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -1489,7 +1489,27 @@ lib_screens += termios09/termios09.scn
 lib_docs += termios09/termios09.doc
 termios09_SOURCES = termios09/init.c
 termios09_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_termios09) \
-	$(support_includes)
+	$(support_includes)
+endif
+if TEST_termios10
+lib_tests += termios10
+lib_screens += termios10/termios10.scn
+lib_docs += termios10/termios10.doc
+termios10_SOURCES  = termios10/init.c
+termios10_SOURCES += termios03/termios_testdriver_polled.c
+termios10_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_termios10) \
+	$(support_includes) -I$(top_srcdir)/termios03
+endif
+if TEST_termios11
+lib_tests += termios11
+lib_screens += termios11/termios11.scn
+lib_docs += termios11/termios11.doc
+termios11_SOURCES  = termios10/init.c
+termios11_SOURCES += termios04/termios_testdriver_intr.c
+termios11_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_termios11) \
+	$(support_includes) -I$(top_srcdir)/termios04 -DINTERRUPT_DRIVEN
 endif
 if TEST_top
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index c02b42a..4d0707c 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -225,6 +225,8 @@ RTEMS_TEST_CHECK([termios06])
 RTEMS_TEST_CHECK([termios07])
 RTEMS_TEST_CHECK([termios08])
 RTEMS_TEST_CHECK([termios09])
+RTEMS_TEST_CHECK([termios10])
+RTEMS_TEST_CHECK([termios11])
 RTEMS_TEST_CHECK([top])
 RTEMS_TEST_CHECK([ttest01])
 RTEMS_TEST_CHECK([tztest])
1.8.3.1
