[RFC PATCH 2/5] riscv: Address differences in the linkerscript between GNU LD and LLVM/LLD
Hesham Almatary
Hesham.Almatary at cl.cam.ac.uk
Wed Oct 23 13:44:10 UTC 2019
LLVM/LLD does not support STARTUP and ALIGN_WITH_INPUT directives that
GNU LD support. INPUT and ALIGN(8) are supported by LLVM/LLD and can
replace the unsupported STARTUP/ALIGN_WITH_INPUT directives.
The commit conditionally adds the supported directive that linkers
can understand depending on the toolchain used to compile RTEMS
i.e., clang or gcc. Clang is assumed to use LLD by default.
bsps/riscv/shared/start/linkcmds.base.in | 102 +++++++++++-----------
c/src/lib/libbsp/riscv/riscv/configure.ac | 13 +++
2 files changed, 64 insertions(+), 51 deletions(-)
diff --git a/bsps/riscv/shared/start/linkcmds.base.in b/bsps/riscv/shared/start/linkcmds.base.in
index 7d889ab38c..857bf2dabd 100644
--- a/bsps/riscv/shared/start/linkcmds.base.in
+++ b/bsps/riscv/shared/start/linkcmds.base.in
@@ -33,7 +33,7 @@
OUTPUT_ARCH(riscv)
ENTRY(_start)
-STARTUP(start.o)
+ at RISCV_LINKER_START_DIRECTIVE@(start.o)
bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1;
bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1;
@@ -43,7 +43,7 @@ MEMORY {
SECTIONS {
- .start : ALIGN_WITH_INPUT {
+ .start : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
bsp_section_start_begin = .;
KEEP (*(.bsp_start_text))
KEEP (*(.bsp_start_data))
@@ -51,7 +51,7 @@ SECTIONS {
} > REGION_START AT > REGION_START
bsp_section_start_size = bsp_section_start_end - bsp_section_start_begin;
- .text : ALIGN_WITH_INPUT {
+ .text : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
bsp_section_text_begin = .;
*(.text.unlikely .text.*_unlikely .text.unlikely.*)
*(.text.exit .text.exit.*)
@@ -61,10 +61,10 @@ SECTIONS {
/* .gnu.warning sections are handled specially by elf32.em. */
*(.gnu.warning)
} > REGION_TEXT AT > REGION_TEXT_LOAD
- .init : ALIGN_WITH_INPUT {
+ .init : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
KEEP (*(SORT_NONE(.init)))
- .fini : ALIGN_WITH_INPUT {
+ .fini : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
KEEP (*(SORT_NONE(.fini)))
bsp_section_text_end = .;
@@ -72,41 +72,41 @@ SECTIONS {
bsp_section_text_load_begin = LOADADDR (.text);
bsp_section_text_load_end = bsp_section_text_load_begin + bsp_section_text_size;
- .robarrier : ALIGN_WITH_INPUT {
+ .robarrier : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
. = ALIGN (bsp_section_robarrier_align);
} > REGION_RODATA AT > REGION_RODATA
- .rodata : ALIGN_WITH_INPUT {
+ .rodata : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
bsp_section_rodata_begin = .;
*(.rodata .rodata.* .gnu.linkonce.r.*)
} > REGION_RODATA AT > REGION_RODATA_LOAD
- .rodata1 : ALIGN_WITH_INPUT {
+ .rodata1 : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.rodata1)
- .sdata2 : ALIGN_WITH_INPUT {
+ .sdata2 : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.sdata2 .sdata2.* .gnu.linkonce.s2.*)
- .sbss2 : ALIGN_WITH_INPUT {
+ .sbss2 : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.sbss2 .sbss2.* .gnu.linkonce.sb2.*)
- .eh_frame_hdr : ALIGN_WITH_INPUT {
+ .eh_frame_hdr : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.eh_frame_hdr) *(.eh_frame_entry .eh_frame_entry.*)
- .eh_frame : ALIGN_WITH_INPUT {
+ .eh_frame : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
KEEP (*(.eh_frame)) *(.eh_frame.*)
- .gcc_except_table : ALIGN_WITH_INPUT {
+ .gcc_except_table : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.gcc_except_table .gcc_except_table.*)
- .gnu_extab : ALIGN_WITH_INPUT {
+ .gnu_extab : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.gnu_extab*)
- .tdata : ALIGN_WITH_INPUT {
+ .tdata : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
_TLS_Data_begin = .;
*(.tdata .tdata.* .gnu.linkonce.td.*)
_TLS_Data_end = .;
- .tbss : ALIGN_WITH_INPUT {
+ .tbss : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
_TLS_BSS_begin = .;
*(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
_TLS_BSS_end = .;
@@ -117,24 +117,24 @@ SECTIONS {
_TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
_TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
_TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
- .preinit_array : ALIGN_WITH_INPUT {
+ .preinit_array : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
PROVIDE_HIDDEN (__preinit_array_start = .);
KEEP (*(.preinit_array))
PROVIDE_HIDDEN (__preinit_array_end = .);
- .init_array : ALIGN_WITH_INPUT {
+ .init_array : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
PROVIDE_HIDDEN (__init_array_start = .);
KEEP (*(SORT_BY_INIT_PRIORITY(.init_array.*) SORT_BY_INIT_PRIORITY(.ctors.*)))
KEEP (*(.init_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .ctors))
PROVIDE_HIDDEN (__init_array_end = .);
- .fini_array : ALIGN_WITH_INPUT {
+ .fini_array : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
PROVIDE_HIDDEN (__fini_array_start = .);
KEEP (*(SORT_BY_INIT_PRIORITY(.fini_array.*) SORT_BY_INIT_PRIORITY(.dtors.*)))
KEEP (*(.fini_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .dtors))
PROVIDE_HIDDEN (__fini_array_end = .);
- .ctors : ALIGN_WITH_INPUT {
+ .ctors : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
/* gcc uses crtbegin.o to find the start of
the constructors, so we make sure it is
first. Because this is a wildcard, it
@@ -154,47 +154,47 @@ SECTIONS {
KEEP (*(SORT(.ctors.*)))
KEEP (*(.ctors))
- .dtors : ALIGN_WITH_INPUT {
+ .dtors : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
KEEP (*crtbegin.o(.dtors))
KEEP (*crtbegin?.o(.dtors))
KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
KEEP (*(SORT(.dtors.*)))
KEEP (*(.dtors))
- .data.rel.ro : ALIGN_WITH_INPUT {
+ .data.rel.ro : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*)
*(.data.rel.ro .data.rel.ro.* .gnu.linkonce.d.rel.ro.*)
- .jcr : ALIGN_WITH_INPUT {
+ .jcr : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
KEEP (*(.jcr))
- .interp : ALIGN_WITH_INPUT {
+ .interp : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.interp)
.note.gnu.build-id : { *(.note.gnu.build-id)
- .hash : ALIGN_WITH_INPUT {
+ .hash : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.hash)
- .gnu.hash : ALIGN_WITH_INPUT {
+ .gnu.hash : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.gnu.hash)
- .dynsym : ALIGN_WITH_INPUT {
+ .dynsym : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.dynsym)
- .dynstr : ALIGN_WITH_INPUT {
+ .dynstr : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.dynstr)
- .gnu.version : ALIGN_WITH_INPUT {
+ .gnu.version : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.gnu.version)
- .gnu.version_d : ALIGN_WITH_INPUT {
+ .gnu.version_d : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.gnu.version_d)
- .gnu.version_r : ALIGN_WITH_INPUT {
+ .gnu.version_r : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.gnu.version_r)
- .rela.dyn : ALIGN_WITH_INPUT {
+ .rela.dyn : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.rela.init)
*(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
*(.rela.fini)
@@ -214,25 +214,25 @@ SECTIONS {
*(.rela.iplt)
PROVIDE_HIDDEN (__rela_iplt_end = .);
- .rela.plt : ALIGN_WITH_INPUT {
+ .rela.plt : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.rela.plt)
- .plt : ALIGN_WITH_INPUT {
+ .plt : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.plt)
- .iplt : ALIGN_WITH_INPUT {
+ .iplt : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.iplt)
- .dynamic : ALIGN_WITH_INPUT {
+ .dynamic : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.dynamic)
- .tm_clone_table : ALIGN_WITH_INPUT {
+ .tm_clone_table : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.tm_clone_table)
- .got : ALIGN_WITH_INPUT {
+ .got : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.got.plt) *(.igot.plt) *(.got) *(.igot)
- .rtemsroset : ALIGN_WITH_INPUT {
+ .rtemsroset : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
/* Special FreeBSD linker set sections */
__start_set_sysctl_set = .;
*(set_sysctl_*);
@@ -247,11 +247,11 @@ SECTIONS {
bsp_section_rodata_load_begin = LOADADDR (.rodata);
bsp_section_rodata_load_end = bsp_section_rodata_load_begin + bsp_section_rodata_size;
- .rwbarrier : ALIGN_WITH_INPUT {
+ .rwbarrier : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
. = ALIGN (bsp_section_rwbarrier_align);
} > REGION_DATA AT > REGION_DATA
- .fast_text : ALIGN_WITH_INPUT {
+ .fast_text : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
bsp_section_fast_text_begin = .;
*(.bsp_fast_text)
bsp_section_fast_text_end = .;
@@ -260,7 +260,7 @@ SECTIONS {
bsp_section_fast_text_load_begin = LOADADDR (.fast_text);
bsp_section_fast_text_load_end = bsp_section_fast_text_load_begin + bsp_section_fast_text_size;
- .fast_data : ALIGN_WITH_INPUT {
+ .fast_data : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
bsp_section_fast_data_begin = .;
*(.bsp_fast_data)
bsp_section_fast_data_end = .;
@@ -269,21 +269,21 @@ SECTIONS {
bsp_section_fast_data_load_begin = LOADADDR (.fast_data);
bsp_section_fast_data_load_end = bsp_section_fast_data_load_begin + bsp_section_fast_data_size;
- .data : ALIGN_WITH_INPUT {
+ .data : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
bsp_section_data_begin = .;
*(.data .data.* .gnu.linkonce.d.*)
SORT(CONSTRUCTORS)
} > REGION_DATA AT > REGION_DATA_LOAD
- .data1 : ALIGN_WITH_INPUT {
+ .data1 : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.data1)
- .rtemsrwset : ALIGN_WITH_INPUT {
+ .rtemsrwset : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
KEEP (*(SORT(.rtemsrwset.*)))
- .htif ALIGN(4096) : ALIGN_WITH_INPUT {
+ .htif ALIGN(4096) : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.htif)
- .sdata : ALIGN_WITH_INPUT {
+ .sdata : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
__global_pointer$ = . + 0x800;
*(.srodata.cst16) *(.srodata.cst8) *(.srodata.cst4) *(.srodata.cst2) *(.srodata .srodata.*)
*(.sdata .sdata.* .gnu.linkonce.s.*)
@@ -293,13 +293,13 @@ SECTIONS {
bsp_section_data_load_begin = LOADADDR (.data);
bsp_section_data_load_end = bsp_section_data_load_begin + bsp_section_data_size;
- .sbss : ALIGN_WITH_INPUT {
+ .sbss : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
bsp_section_bss_begin = .;
*(.dynsbss)
*(.sbss .sbss.* .gnu.linkonce.sb.*)
*(.scommon)
- .bss : ALIGN_WITH_INPUT {
+ .bss : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
*(.dynbss)
*(.bss .bss.* .gnu.linkonce.b.*)
*(COMMON)
@@ -307,14 +307,14 @@ SECTIONS {
bsp_section_bss_size = bsp_section_bss_end - bsp_section_bss_begin;
- .rtemsstack (NOLOAD) : ALIGN_WITH_INPUT {
+ .rtemsstack (NOLOAD) : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
bsp_section_rtemsstack_begin = .;
*(SORT(.rtemsstack.*))
bsp_section_rtemsstack_end = .;
} > REGION_RTEMSSTACK AT > REGION_RTEMSSTACK
bsp_section_rtemsstack_size = bsp_section_rtemsstack_end - bsp_section_rtemsstack_begin;
- .work : ALIGN_WITH_INPUT {
+ .work : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
* The work section will occupy the remaining REGION_WORK region and
* contains the RTEMS work space and heap.
diff --git a/c/src/lib/libbsp/riscv/riscv/configure.ac b/c/src/lib/libbsp/riscv/riscv/configure.ac
index af501badf2..4494a03536 100644
--- a/c/src/lib/libbsp/riscv/riscv/configure.ac
+++ b/c/src/lib/libbsp/riscv/riscv/configure.ac
@@ -67,6 +67,17 @@ case "${RTEMS_BSP}" in
esac
+case "${RTEMS_BSP}" in
+ *clang)
+ RISCV_LINKER_START_DIRECTIVE_DEFAULT="INPUT"
+ RISCV_LINKER_ALIGN_DIRECTIVE_DEFAULT="ALIGN(8)"
+ RISCV_LINKER_START_DIRECTIVE_DEFAULT="STARTUP"
+ RISCV_LINKER_ALIGN_DIRECTIVE_DEFAULT="ALIGN_WITH_INPUT"
+esac
AC_DEFUN([RISCV_LINKCMD],[
AC_ARG_VAR([$1],[$2])dnl
[$1]=[$]{[$1]:-[$3]}
@@ -74,6 +85,8 @@ AC_ARG_VAR([$1],[$2])dnl
RISCV_LINKCMD([RISCV_RAM_REGION_BEGIN],[begin of the RAM region for linker command file (default is 0x70000000 for 64-bit with -mcmodel=medlow and 0x80000000 for all other)],[${RISCV_RAM_REGION_BEGIN_DEFAULT}])
RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default is 256 MiB for frdme310arty and 64 MiB for all other)],[${RISCV_RAM_REGION_SIZE_DEFAULT}])
+RISCV_LINKCMD([RISCV_LINKER_START_DIRECTIVE],[GNU LD understands STARTUP directive while LLVM/LLD does not and needs INPUT instead],[${RISCV_LINKER_START_DIRECTIVE_DEFAULT}])
+RISCV_LINKCMD([RISCV_LINKER_ALIGN_DIRECTIVE],[LLD does not support ALIGN_WITH_INPUT directive],[${RISCV_LINKER_ALIGN_DIRECTIVE_DEFAULT}])
AC_CONFIG_FILES([
Makefile
2.17.1
