[RFC PATCH 2/5] riscv: Address differences in the linkerscript between GNU LD and LLVM/LLD
Hesham Almatary
hesham.almatary at cl.cam.ac.uk
Thu Oct 24 09:15:48 UTC 2019
On Thu, 24 Oct 2019 at 09:58, Sebastian Huber
> On 23/10/2019 15:44, Hesham Almatary wrote:
> > LLVM/LLD does not support STARTUP and ALIGN_WITH_INPUT directives that
> > GNU LD support. INPUT and ALIGN(8) are supported by LLVM/LLD and can
> > replace the unsupported STARTUP/ALIGN_WITH_INPUT directives.
> > The commit conditionally adds the supported directive that linkers
> > can understand depending on the toolchain used to compile RTEMS
> > i.e., clang or gcc. Clang is assumed to use LLD by default.
> > bsps/riscv/shared/start/linkcmds.base.in | 102 +++++++++++-----------
> > c/src/lib/libbsp/riscv/riscv/configure.ac | 13 +++
> > 2 files changed, 64 insertions(+), 51 deletions(-)
> > diff --git a/bsps/riscv/shared/start/linkcmds.base.in b/bsps/riscv/shared/start/linkcmds.base.in
> > index 7d889ab38c..857bf2dabd 100644
> > --- a/bsps/riscv/shared/start/linkcmds.base.in
> > +++ b/bsps/riscv/shared/start/linkcmds.base.in
> > @@ -33,7 +33,7 @@
> > OUTPUT_ARCH(riscv)
> > ENTRY(_start)
> > -STARTUP(start.o)
> > + at RISCV_LINKER_START_DIRECTIVE@(start.o)
> Works INPUT() instead of STARTUP() with GNU ld as well?
Unfortunately not. It complains about undefined references in start.o
(because of the un(order) the libs and start.o are linked)
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
