[PATCH v2 2/5] riscv: Address differences in the linkerscript between GNU LD and LLVM/LLD
Hesham Almatary Hesham.Almatary at cl.cam.ac.uk
Thu Oct 24 14:25:36 UTC 2019
LLVM/LLD does not support STARTUP and ALIGN_WITH_INPUT directives that
GNU LD support. INPUT and ALIGN(8) are supported by LLVM/LLD and can
replace the unsupported STARTUP/ALIGN_WITH_INPUT directives.
The commit conditionally adds the supported directive that linkers
can understand depending on the toolchain used to compile RTEMS
i.e., clang or gcc. Clang is assumed to use LLD by default.
 bsps/riscv/shared/start/linkcmds.base.in   | 102 ++++++++++-----------
 c/src/lib/libbsp/riscv/griscv/Makefile.am  |   2 +-
 c/src/lib/libbsp/riscv/griscv/configure.ac |  19 ++++
 c/src/lib/libbsp/riscv/riscv/configure.ac  |  13 +++
 4 files changed, 84 insertions(+), 52 deletions(-)
diff --git a/bsps/riscv/shared/start/linkcmds.base.in b/bsps/riscv/shared/start/linkcmds.base.in
index 7d889ab38c..857bf2dabd 100644
--- a/bsps/riscv/shared/start/linkcmds.base.in
+++ b/bsps/riscv/shared/start/linkcmds.base.in
@@ -33,7 +33,7 @@
 OUTPUT_ARCH(riscv)
 ENTRY(_start)
-STARTUP(start.o)
+ at RISCV_LINKER_START_DIRECTIVE@(start.o)
 bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1;
 bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1;
@@ -43,7 +43,7 @@ MEMORY {
 SECTIONS {
-	.start : ALIGN_WITH_INPUT {
+	.start : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		bsp_section_start_begin = .;
 		KEEP (*(.bsp_start_text))
 		KEEP (*(.bsp_start_data))
@@ -51,7 +51,7 @@ SECTIONS {
 	} > REGION_START AT > REGION_START
 	bsp_section_start_size = bsp_section_start_end - bsp_section_start_begin;
-	.text : ALIGN_WITH_INPUT {
+	.text : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		bsp_section_text_begin = .;
 		*(.text.unlikely .text.*_unlikely .text.unlikely.*)
 		*(.text.exit .text.exit.*)
@@ -61,10 +61,10 @@ SECTIONS {
 		/* .gnu.warning sections are handled specially by elf32.em.	*/
 		*(.gnu.warning)
 	} > REGION_TEXT AT > REGION_TEXT_LOAD
-	.init : ALIGN_WITH_INPUT {
+	.init : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		KEEP (*(SORT_NONE(.init)))
-	.fini : ALIGN_WITH_INPUT {
+	.fini : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		KEEP (*(SORT_NONE(.fini)))
 		bsp_section_text_end = .;
@@ -72,41 +72,41 @@ SECTIONS {
 	bsp_section_text_load_begin = LOADADDR (.text);
 	bsp_section_text_load_end = bsp_section_text_load_begin + bsp_section_text_size;
-	.robarrier : ALIGN_WITH_INPUT {
+	.robarrier : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		. = ALIGN (bsp_section_robarrier_align);
 	} > REGION_RODATA AT > REGION_RODATA
-	.rodata : ALIGN_WITH_INPUT {
+	.rodata : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		bsp_section_rodata_begin = .;
 		*(.rodata .rodata.* .gnu.linkonce.r.*)
 	} > REGION_RODATA AT > REGION_RODATA_LOAD
-	.rodata1 : ALIGN_WITH_INPUT {
+	.rodata1 : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.rodata1)
-	.sdata2 : ALIGN_WITH_INPUT {
+	.sdata2 : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.sdata2 .sdata2.* .gnu.linkonce.s2.*)
-	.sbss2 : ALIGN_WITH_INPUT {
+	.sbss2 : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.sbss2 .sbss2.* .gnu.linkonce.sb2.*)
-	.eh_frame_hdr : ALIGN_WITH_INPUT {
+	.eh_frame_hdr : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.eh_frame_hdr) *(.eh_frame_entry .eh_frame_entry.*)
-	.eh_frame : ALIGN_WITH_INPUT {
+	.eh_frame : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		KEEP (*(.eh_frame)) *(.eh_frame.*)
-	.gcc_except_table : ALIGN_WITH_INPUT {
+	.gcc_except_table : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.gcc_except_table .gcc_except_table.*)
-	.gnu_extab : ALIGN_WITH_INPUT {
+	.gnu_extab : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.gnu_extab*)
-	.tdata : ALIGN_WITH_INPUT {
+	.tdata : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		_TLS_Data_begin = .;
 		*(.tdata .tdata.* .gnu.linkonce.td.*)
 		_TLS_Data_end = .;
-	.tbss : ALIGN_WITH_INPUT {
+	.tbss : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		_TLS_BSS_begin = .;
 		*(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
 		_TLS_BSS_end = .;
@@ -117,24 +117,24 @@ SECTIONS {
 	_TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
 	_TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
 	_TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
-	.preinit_array : ALIGN_WITH_INPUT {
+	.preinit_array : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		PROVIDE_HIDDEN (__preinit_array_start = .);
 		KEEP (*(.preinit_array))
 		PROVIDE_HIDDEN (__preinit_array_end = .);
-	.init_array : ALIGN_WITH_INPUT {
+	.init_array : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		PROVIDE_HIDDEN (__init_array_start = .);
 		KEEP (*(SORT_BY_INIT_PRIORITY(.init_array.*) SORT_BY_INIT_PRIORITY(.ctors.*)))
 		KEEP (*(.init_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .ctors))
 		PROVIDE_HIDDEN (__init_array_end = .);
-	.fini_array : ALIGN_WITH_INPUT {
+	.fini_array : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		PROVIDE_HIDDEN (__fini_array_start = .);
 		KEEP (*(SORT_BY_INIT_PRIORITY(.fini_array.*) SORT_BY_INIT_PRIORITY(.dtors.*)))
 		KEEP (*(.fini_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .dtors))
 		PROVIDE_HIDDEN (__fini_array_end = .);
-	.ctors : ALIGN_WITH_INPUT {
+	.ctors : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		/* gcc uses crtbegin.o to find the start of
 			 the constructors, so we make sure it is
 			 first.	Because this is a wildcard, it
@@ -154,47 +154,47 @@ SECTIONS {
 		KEEP (*(SORT(.ctors.*)))
 		KEEP (*(.ctors))
-	.dtors : ALIGN_WITH_INPUT {
+	.dtors : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		KEEP (*crtbegin.o(.dtors))
 		KEEP (*crtbegin?.o(.dtors))
 		KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
 		KEEP (*(SORT(.dtors.*)))
 		KEEP (*(.dtors))
-	.data.rel.ro : ALIGN_WITH_INPUT {
+	.data.rel.ro : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*)
 		*(.data.rel.ro .data.rel.ro.* .gnu.linkonce.d.rel.ro.*)
-	.jcr : ALIGN_WITH_INPUT {
+	.jcr : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		KEEP (*(.jcr))
-	.interp : ALIGN_WITH_INPUT {
+	.interp : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.interp)
 	.note.gnu.build-id : { *(.note.gnu.build-id)
-	.hash : ALIGN_WITH_INPUT {
+	.hash : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.hash)
-	.gnu.hash : ALIGN_WITH_INPUT {
+	.gnu.hash : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.gnu.hash)
-	.dynsym : ALIGN_WITH_INPUT {
+	.dynsym : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.dynsym)
-	.dynstr : ALIGN_WITH_INPUT {
+	.dynstr : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.dynstr)
-	.gnu.version : ALIGN_WITH_INPUT {
+	.gnu.version : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.gnu.version)
-	.gnu.version_d : ALIGN_WITH_INPUT {
+	.gnu.version_d : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.gnu.version_d)
-	.gnu.version_r : ALIGN_WITH_INPUT {
+	.gnu.version_r : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.gnu.version_r)
-	.rela.dyn : ALIGN_WITH_INPUT {
+	.rela.dyn : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.rela.init)
 		*(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
 		*(.rela.fini)
@@ -214,25 +214,25 @@ SECTIONS {
 		*(.rela.iplt)
 		PROVIDE_HIDDEN (__rela_iplt_end = .);
-	.rela.plt : ALIGN_WITH_INPUT {
+	.rela.plt : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 			*(.rela.plt)
-	.plt : ALIGN_WITH_INPUT {
+	.plt : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.plt)
-	.iplt : ALIGN_WITH_INPUT {
+	.iplt : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.iplt)
-	.dynamic : ALIGN_WITH_INPUT {
+	.dynamic : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.dynamic)
-	.tm_clone_table : ALIGN_WITH_INPUT {
+	.tm_clone_table : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.tm_clone_table)
-	.got : ALIGN_WITH_INPUT {
+	.got : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.got.plt) *(.igot.plt) *(.got) *(.igot)
-	.rtemsroset : ALIGN_WITH_INPUT {
+	.rtemsroset : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		/* Special FreeBSD linker set sections */
 		__start_set_sysctl_set = .;
 		*(set_sysctl_*);
@@ -247,11 +247,11 @@ SECTIONS {
 	bsp_section_rodata_load_begin = LOADADDR (.rodata);
 	bsp_section_rodata_load_end = bsp_section_rodata_load_begin + bsp_section_rodata_size;
-	.rwbarrier : ALIGN_WITH_INPUT {
+	.rwbarrier : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		. = ALIGN (bsp_section_rwbarrier_align);
 	} > REGION_DATA AT > REGION_DATA
-	.fast_text : ALIGN_WITH_INPUT {
+	.fast_text : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		bsp_section_fast_text_begin = .;
 		*(.bsp_fast_text)
 		bsp_section_fast_text_end = .;
@@ -260,7 +260,7 @@ SECTIONS {
 	bsp_section_fast_text_load_begin = LOADADDR (.fast_text);
 	bsp_section_fast_text_load_end = bsp_section_fast_text_load_begin + bsp_section_fast_text_size;
-	.fast_data : ALIGN_WITH_INPUT {
+	.fast_data : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		bsp_section_fast_data_begin = .;
 		*(.bsp_fast_data)
 		bsp_section_fast_data_end = .;
@@ -269,21 +269,21 @@ SECTIONS {
 	bsp_section_fast_data_load_begin = LOADADDR (.fast_data);
 	bsp_section_fast_data_load_end = bsp_section_fast_data_load_begin + bsp_section_fast_data_size;
-	.data : ALIGN_WITH_INPUT {
+	.data : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		bsp_section_data_begin = .;
 		*(.data .data.* .gnu.linkonce.d.*)
 		SORT(CONSTRUCTORS)
 	} > REGION_DATA AT > REGION_DATA_LOAD
-	.data1 : ALIGN_WITH_INPUT {
+	.data1 : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.data1)
-	.rtemsrwset : ALIGN_WITH_INPUT {
+	.rtemsrwset : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		KEEP (*(SORT(.rtemsrwset.*)))
-	.htif ALIGN(4096) : ALIGN_WITH_INPUT {
+	.htif ALIGN(4096) : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.htif)
-	.sdata : ALIGN_WITH_INPUT {
+	.sdata : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		__global_pointer$ = . + 0x800;
 		*(.srodata.cst16) *(.srodata.cst8) *(.srodata.cst4) *(.srodata.cst2) *(.srodata .srodata.*)
 		*(.sdata .sdata.* .gnu.linkonce.s.*)
@@ -293,13 +293,13 @@ SECTIONS {
 	bsp_section_data_load_begin = LOADADDR (.data);
 	bsp_section_data_load_end = bsp_section_data_load_begin + bsp_section_data_size;
-	.sbss : ALIGN_WITH_INPUT {
+	.sbss : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		bsp_section_bss_begin = .;
 		*(.dynsbss)
 		*(.sbss .sbss.* .gnu.linkonce.sb.*)
 		*(.scommon)
-	.bss : ALIGN_WITH_INPUT {
+	.bss : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		*(.dynbss)
 		*(.bss .bss.* .gnu.linkonce.b.*)
 		*(COMMON)
@@ -307,14 +307,14 @@ SECTIONS {
 	bsp_section_bss_size = bsp_section_bss_end - bsp_section_bss_begin;
-	.rtemsstack (NOLOAD) : ALIGN_WITH_INPUT {
+	.rtemsstack (NOLOAD) : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		bsp_section_rtemsstack_begin = .;
 		*(SORT(.rtemsstack.*))
 		bsp_section_rtemsstack_end = .;
 	} > REGION_RTEMSSTACK AT > REGION_RTEMSSTACK
 	bsp_section_rtemsstack_size = bsp_section_rtemsstack_end - bsp_section_rtemsstack_begin;
-	.work : ALIGN_WITH_INPUT {
+	.work : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		 * The work section will occupy the remaining REGION_WORK region and
 		 * contains the RTEMS work space and heap.
diff --git a/c/src/lib/libbsp/riscv/griscv/Makefile.am b/c/src/lib/libbsp/riscv/griscv/Makefile.am
index 4077ddebd2..e04598e4bf 100644
--- a/c/src/lib/libbsp/riscv/griscv/Makefile.am
+++ b/c/src/lib/libbsp/riscv/griscv/Makefile.am
@@ -23,7 +23,7 @@ start.$(OBJEXT): ../../../../../../bsps/riscv/shared/start/start.S
 project_lib_DATA = start.$(OBJEXT)
 project_lib_DATA += linkcmds
-project_lib_DATA += ../../../../../../bsps/riscv/shared/start/linkcmds.base
+project_lib_DATA += linkcmds.base
 #                  LibBSP                                                     #
diff --git a/c/src/lib/libbsp/riscv/griscv/configure.ac b/c/src/lib/libbsp/riscv/griscv/configure.ac
index ed5694c763..a92676169f 100644
--- a/c/src/lib/libbsp/riscv/griscv/configure.ac
+++ b/c/src/lib/libbsp/riscv/griscv/configure.ac
@@ -30,11 +30,30 @@ AC_ARG_VAR([$1],[$2])dnl
 [$1]=[$]{[$1]:-[$3]}
+case "${RTEMS_BSP}" in
+  *clang)
+    RISCV_LINKER_START_DIRECTIVE_DEFAULT="INPUT"
+    RISCV_LINKER_ALIGN_DIRECTIVE_DEFAULT="ALIGN(8)"
+    RISCV_LINKER_START_DIRECTIVE_DEFAULT="STARTUP"
+    RISCV_LINKER_ALIGN_DIRECTIVE_DEFAULT="ALIGN_WITH_INPUT"
+esac
+AC_DEFUN([RISCV_LINKCMD],[
+AC_ARG_VAR([$1],[$2])dnl
+[$1]=[$]{[$1]:-[$3]}
 RISCV_LINKCMD([RISCV_RAM_REGION_BEGIN],[begin of the RAM region for linker command file (default is 0x40000000)],[${RISCV_RAM_REGION_BEGIN_DEFAULT}])
 RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default 16MiB)],[0x01000000])
+RISCV_LINKCMD([RISCV_LINKER_START_DIRECTIVE],[GNU LD understands STARTUP directive while LLVM/LLD does not and needs INPUT instead],[${RISCV_LINKER_START_DIRECTIVE_DEFAULT}])
+RISCV_LINKCMD([RISCV_LINKER_ALIGN_DIRECTIVE],[LLD does not support ALIGN_WITH_INPUT directive],[${RISCV_LINKER_ALIGN_DIRECTIVE_DEFAULT}])
 AC_CONFIG_FILES([
 Makefile
 linkcmds:../../../../../../bsps/riscv/griscv/start/linkcmds.in
+linkcmds.base:../../../../../../bsps/riscv/shared/start/linkcmds.base.in
 AC_OUTPUT
diff --git a/c/src/lib/libbsp/riscv/riscv/configure.ac b/c/src/lib/libbsp/riscv/riscv/configure.ac
index af501badf2..4494a03536 100644
--- a/c/src/lib/libbsp/riscv/riscv/configure.ac
+++ b/c/src/lib/libbsp/riscv/riscv/configure.ac
@@ -67,6 +67,17 @@ case "${RTEMS_BSP}" in
 esac
+  *clang)
+esac
@@ -74,6 +85,8 @@ AC_ARG_VAR([$1],[$2])dnl
 RISCV_LINKCMD([RISCV_RAM_REGION_BEGIN],[begin of the RAM region for linker command file (default is 0x70000000 for 64-bit with -mcmodel=medlow and 0x80000000 for all other)],[${RISCV_RAM_REGION_BEGIN_DEFAULT}])
 RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default is 256 MiB for frdme310arty and 64 MiB for all other)],[${RISCV_RAM_REGION_SIZE_DEFAULT}])
 AC_CONFIG_FILES([
 Makefile
2.17.1
