[PATCH v2 3/5] riscv: Add NOLOAD directive to the .work section
    Hesham Almatary
    Hesham.Almatary at cl.cam.ac.uk
    Thu Oct 24 14:25:37 UTC 2019
ld.lld defaults .work to PROGBITS otherwise
 bsps/riscv/shared/start/linkcmds.base.in | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bsps/riscv/shared/start/linkcmds.base.in b/bsps/riscv/shared/start/linkcmds.base.in
index 857bf2dabd..7d6a23cde0 100644
--- a/bsps/riscv/shared/start/linkcmds.base.in
+++ b/bsps/riscv/shared/start/linkcmds.base.in
@@ -314,7 +314,7 @@ SECTIONS {
 	} > REGION_RTEMSSTACK AT > REGION_RTEMSSTACK
 	bsp_section_rtemsstack_size = bsp_section_rtemsstack_end - bsp_section_rtemsstack_begin;
-	.work : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
+	.work (NOLOAD) : @RISCV_LINKER_ALIGN_DIRECTIVE@ {
 		 * The work section will occupy the remaining REGION_WORK region and
 		 * contains the RTEMS work space and heap.
2.17.1
