Attributes in build specification items
    Sebastian Huber
    Fri Oct 25 08:34:55 UTC 2019
Hello,
for the new build system the specification what to build is contained in
so called build specification items. The items are files in YAML format
and are maintained by Doorstop and a text editor. For example a build
specification item for an integer configuration option could look like:
active: true
build-type: integer-option
default: 100000000
default-by-variant:
- value: 333333333
   variant: xilinx_zynq_zc702
- value: 666666667
   variant: xilinx_zynq_zedboard
derived: false
header: ''
level: 1.5
links: []
normative: true
ref: ''
reviewed: cKwFFKjf_aPPFZe7fKyxBqYcAqdvU2A0yQaBdhbONQ8=
text: |
   ARM Cortex-A9 MPCore PERIPHCLK clock frequency in Hz
type: build
How do we want to handle optional attributes (e.g. min)? Should we
mandate that they are always present in the item file, e.g.
min: null
or should it be able to omit them and use default values in the wscript,
e.g.
min = self.data.get("min", None)
if min not None:
	if value < min:
		error()
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
