[PATCH v2] [rsb] Update Spike build
Hesham Almatary hesham.almatary at cl.cam.ac.uk
Sun Oct 27 10:37:47 UTC 2019
Yeah fesvr is now part of Spike in-tree. I didn't like it had to be
built separately either [1].
Joel, AFAIR, dtc was always needed.
[1] https://github.com/riscv/riscv-isa-sim/issues/254
On Fri, 25 Oct 2019 at 14:59, Joel Sherrill <joel at rtems.org> wrote:
> Thanks for updating this.
> When building on a very clean machine, dtc needs to be referenced and in the PATH.
> hecking for dtc... no
> configure: error: device-tree-compiler not found
> Is this working for you when dtc is not installed before building spike?
> On Thu, Oct 24, 2019 at 4:39 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 24/10/19 7:57 pm, Hesham Almatary wrote:
>> > Latest Spike integrated fesvr in its source directory, so there
>> > is no separate fesvr anymore.
>> Nice. Building and installing fesvr was a little unusual.
>> Chris
>> devel mailing list
>> devel at rtems.org
