[PATCH] riscv: Rename new *_clang.cfg file to *_clang.ccfg
Hesham Almatary Hesham.Almatary at cl.cam.ac.uk
Tue Oct 29 09:34:28 UTC 2019
This is to hide the new BSPs from GCC builds when building
all RISC-V BSPs with configure --target=riscv-rtems5
 .../config/{rv32i_clang.cfg => rv32i_clang.ccfg}   |  0
 .../{rv32iac_clang.cfg => rv32iac_clang.ccfg}      |  0
 .../config/{rv32im_clang.cfg => rv32im_clang.ccfg} |  0
 .../{rv32imac_clang.cfg => rv32imac_clang.ccfg}    |  0
 bsps/riscv/riscv/config/rv32imafc_clang.ccfg       | 14 ++++++++++++++
 bsps/riscv/riscv/config/rv32imafc_clang.cfg        | 14 --------------
 .../{rv32imafd_clang.cfg => rv32imafd_clang.ccfg}  |  0
 ...{rv32imafdc_clang.cfg => rv32imafdc_clang.ccfg} |  0
 ...{rv64imafdc_clang.cfg => rv64imafdc_clang.ccfg} |  0
 9 files changed, 14 insertions(+), 14 deletions(-)
 rename bsps/riscv/riscv/config/{rv32i_clang.cfg => rv32i_clang.ccfg} (100%)
 rename bsps/riscv/riscv/config/{rv32iac_clang.cfg => rv32iac_clang.ccfg} (100%)
 rename bsps/riscv/riscv/config/{rv32im_clang.cfg => rv32im_clang.ccfg} (100%)
 rename bsps/riscv/riscv/config/{rv32imac_clang.cfg => rv32imac_clang.ccfg} (100%)
 create mode 100644 bsps/riscv/riscv/config/rv32imafc_clang.ccfg
 delete mode 100644 bsps/riscv/riscv/config/rv32imafc_clang.cfg
 rename bsps/riscv/riscv/config/{rv32imafd_clang.cfg => rv32imafd_clang.ccfg} (100%)
 rename bsps/riscv/riscv/config/{rv32imafdc_clang.cfg => rv32imafdc_clang.ccfg} (100%)
 rename bsps/riscv/riscv/config/{rv64imafdc_clang.cfg => rv64imafdc_clang.ccfg} (100%)
diff --git a/bsps/riscv/riscv/config/rv32i_clang.cfg b/bsps/riscv/riscv/config/rv32i_clang.ccfg
similarity index 100%
rename from bsps/riscv/riscv/config/rv32i_clang.cfg
rename to bsps/riscv/riscv/config/rv32i_clang.ccfg
diff --git a/bsps/riscv/riscv/config/rv32iac_clang.cfg b/bsps/riscv/riscv/config/rv32iac_clang.ccfg
rename from bsps/riscv/riscv/config/rv32iac_clang.cfg
rename to bsps/riscv/riscv/config/rv32iac_clang.ccfg
diff --git a/bsps/riscv/riscv/config/rv32im_clang.cfg b/bsps/riscv/riscv/config/rv32im_clang.ccfg
rename from bsps/riscv/riscv/config/rv32im_clang.cfg
rename to bsps/riscv/riscv/config/rv32im_clang.ccfg
diff --git a/bsps/riscv/riscv/config/rv32imac_clang.cfg b/bsps/riscv/riscv/config/rv32imac_clang.ccfg
rename from bsps/riscv/riscv/config/rv32imac_clang.cfg
rename to bsps/riscv/riscv/config/rv32imac_clang.ccfg
diff --git a/bsps/riscv/riscv/config/rv32imafc_clang.ccfg b/bsps/riscv/riscv/config/rv32imafc_clang.ccfg
new file mode 100644
index 0000000000..74cf7c5625
--- /dev/null
+++ b/bsps/riscv/riscv/config/rv32imafc_clang.ccfg
@@ -0,0 +1,14 @@
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = riscv
+CPU_CFLAGS = -march=rv32imafc -mabi=ilp32f
+# Clang-related flags
+CPU_CFLAGS += -target riscv32-unknown-rtems6 --sysroot=$(NEWLIB_SYSROOT)
+LDFLAGS = -Wl,--gc-sections -L$(RTEMS_BSP_LIBBSP_PATH) -L$(PROJECT_LIB) -L$(RTEMS_BSP_ARCH_LINKCMDS_PATH)
+CFLAGS_OPTIMIZE_V ?= -O0 -g -ffunction-sections -fdata-sections
diff --git a/bsps/riscv/riscv/config/rv32imafc_clang.cfg b/bsps/riscv/riscv/config/rv32imafc_clang.cfg
deleted file mode 100644
index 3d344ba3db..0000000000
--- a/bsps/riscv/riscv/config/rv32imafc_clang.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
-include $(RTEMS_ROOT)/make/custom/default.cfg
-RTEMS_CPU = riscv
-CPU_CFLAGS = -march=rv32imafc -mabi=ilp32d
-# Clang-related flags
-CPU_CFLAGS += -target riscv32-unknown-rtems6 --sysroot=$(NEWLIB_SYSROOT)
-LDFLAGS = -Wl,--gc-sections -L$(RTEMS_BSP_LIBBSP_PATH) -L$(PROJECT_LIB) -L$(RTEMS_BSP_ARCH_LINKCMDS_PATH)
-CFLAGS_OPTIMIZE_V ?= -O0 -g -ffunction-sections -fdata-sections
diff --git a/bsps/riscv/riscv/config/rv32imafd_clang.cfg b/bsps/riscv/riscv/config/rv32imafd_clang.ccfg
rename from bsps/riscv/riscv/config/rv32imafd_clang.cfg
rename to bsps/riscv/riscv/config/rv32imafd_clang.ccfg
diff --git a/bsps/riscv/riscv/config/rv32imafdc_clang.cfg b/bsps/riscv/riscv/config/rv32imafdc_clang.ccfg
rename from bsps/riscv/riscv/config/rv32imafdc_clang.cfg
rename to bsps/riscv/riscv/config/rv32imafdc_clang.ccfg
diff --git a/bsps/riscv/riscv/config/rv64imafdc_clang.cfg b/bsps/riscv/riscv/config/rv64imafdc_clang.ccfg
rename from bsps/riscv/riscv/config/rv64imafdc_clang.cfg
rename to bsps/riscv/riscv/config/rv64imafdc_clang.ccfg
2.17.1
