[PATCH v2] [rsb] Update Spike build
Wed Oct 30 15:17:01 UTC 2019
>From my perspective, yes. If it breaks something else, we can fix that.
On Wed, Oct 30, 2019 at 9:47 AM Hesham Almatary <
hesham.almatary at cl.cam.ac.uk> wrote:
> OK to push?
> On Tue, 29 Oct 2019 at 09:25, Hesham Almatary
> <hesham.almatary at cl.cam.ac.uk> wrote:
> > On Mon, 28 Oct 2019 at 23:15, Joel Sherrill <joel at rtems.org> wrote:
> > > On Mon, Oct 28, 2019 at 5:20 AM Hesham Almatary <
> > >> On Mon, 28 Oct 2019 at 04:01, Chris Johns <chrisj at rtems.org> wrote:
> > >> > On 28/10/19 9:21 am, Hesham Almatary wrote:
> > >> > > On Sun, 27 Oct 2019 at 20:54, Chris Johns <chrisj at rtems.org
> > >> > > <mailto:chrisj at rtems.org>> wrote:
> > >> > >     On 27/10/19 9:37 pm, Hesham Almatary wrote:
> > >> > >     > Yeah fesvr is now part of Spike in-tree. I didn't like it
> had to be
> > >> > >     > built separately either [1].
> > >> > >     > Joel, AFAIR, dtc was always needed.
> > >> > >     Please have the package build FDT if it is needed. Do no rely
> on it being
> > >> > >     installed as some hosts do not have a package to install.
> > >> > > I think Joel has already added it
> https://github.com/RTEMS/rtems-source-builder/blob/master/bare/config/devel/spike.bset#L7
> > >> > Thanks.
> > >> > The config file has some issues. I am fixing the %hash issues. Is
> the patch
> > >> > still needed if the version used has the fix?
> > >> The version that has the fix is a recent one, and it has fesvr in its
> > >> source tree, hence, there's no separate fesvr any more. The patch will
> > >> still be needed to get rid of the separate fesvr build for this recent
> > >> Spike revision.
> > > If you are bumping to a version which doesn't need my patch, great!
> > Yes, that's the point of the patch along with removing fesvr build.
> > > Is this all pushed now?
> > Not yet, waiting for approval.
> > >> > Chris
> > >> > _______________________________________________
> > >> > devel mailing list
> > >> > devel at rtems.org
> > >> > http://lists.rtems.org/mailman/listinfo/devel
> > >> devel mailing list
> > >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191030/6b0d049c/attachment.html>
