[PATCH] record: Add wrappers for malloc() functions
Mon Sep 2 05:37:57 UTC 2019
On 01/09/2019 04:29, Chris Johns wrote:
> On 30/8/19 11:07 pm, Sebastian Huber wrote:
>> Introduce new library librtemsrecordwrap.a which contains wrappers for
>> operating system functions which produce entry/exit events.
> Why not enhance the trace linker to handle the recorder you have developed? It
> has been able to wrap malloc and friends for a while now, it is just lacking
> support for your recent tracing effort.
> Currently the trace linker does not uses the DWARF information to determine the
> function signature as the DWARF support was added to the tool kit after it was
> created and it has not been updated. The idea is to have DWARF provide the
> signature of any suitable function so it can be wrapped.
With the DWARF information at hand it should be possible to generate
generic record events for function calls with up to 10 input arguments
(RTEMS_RECORD_ARG_[0-9]) and up to 10 return values
(RTEMS_RECORD_RETURN_[0-9]). We need two events for generic function
entry/exit:
RTEMS_RECORD_FUNCTION_ENTRY
RTEMS_RECORD_FUNCTION_EXIT
The event data for these two is the function address.
> I do not see any upside adding this library or wrapping specific functions this way.
The benefits are:
* Slightly more compact (the event indicates the function and the data
can be used for the caller address instead, the generic function
entry/exit needs two events for this).
* It works without extra tools to build the application.
* It can be tested through the RTEMS test suite.
* You don't need the ELF file to produce a report.
The only strong argument is the first one. A future support in the trace
linker could use the librtemsrecordwrap.a and only generate generic
stubs for other functions.
Adding the DWARF support could be a GSoC 2020 project.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
