[PATCH] record: Add wrappers for malloc() functions
Mon Sep 2 07:11:54 UTC 2019
On 02/09/2019 09:00, Chris Johns wrote:
> Why not generate the call to `rtems_record_produce_2`? You should be able to
> determine this give you will know there in a single item plus the return address
> to record. In fact there is little need for `rtems_record_produce_n` if you have
> [1..n] already defined.
The rtems_record_produce_2() is just an optimization since most
architectures accept up to four arguments via registers. The particular
rtems_record_produce*() function is not the issue here.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
