[PATCH] Add lvgl_hello: Sample Hello world app using littleVGL and libbsd
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon Sep 2 18:56:50 UTC 2019
> > +void
>> > +libbsdhelper_start_shell(rtems_task_priority prio)
>> > + rtems_status_code sc = rtems_shell_init(
>> > + "SHLL",
>> > + STACK_SIZE_SHELL,
>> > + prio,
>> > + CONSOLE_DEVICE_NAME,
>> > + false,
>> > + true,
>> > + NULL
>> > + assert(sc == RTEMS_SUCCESSFUL);
>> > +static void
>> > +Init(rtems_task_argument arg)
>> > + rtems_status_code sc;
>> > + int exit_code;
>> > + (void)arg;
>> > + static lv_color_t buf[LV_HOR_RES_MAX*10];
>> > + static lv_disp_buf_t disp_buf;
>> > + puts("\nRTEMS I2C TEST\n");
>> > + exit_code = bbb_register_i2c_0();
>> > + assert(exit_code == 0);
>> Is this needed for the display to work?
>> Yes. We need to register the rtems i2c device in order to work with the
> TDA driver
> as libbsd uses rtems i2c driver. The bbb_register_* is making it bbb
> specific, what
> do you suggest to make it more generic?
A good reference I could find is in:
https://git.rtems.org/rtems/tree/testsuites/libtests/i2c01/init.c#n534
Should I do something like this in the lvgl example?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190903/49032aa6/attachment.html>
