[PATCH] record: Add support for interrupt handlers
Wed Sep 4 06:44:10 UTC 2019
On 4/9/19 4:27 pm, Sebastian Huber wrote:
> On 04/09/2019 08:06, Chris Johns wrote:
>>>   void LTTNGClient::AddThreadName(PerCPUContext* pcpu, const ClientItem& item) {
>>>     if (pcpu->thread_name_index >= THREAD_NAME_SIZE) {
>>>       return;
>>> @@ -286,6 +339,12 @@ void LTTNGClient::PrintItem(const ClientItem& item) {
>>>         pcpu.thread_ns = item.ns;
>>>         pcpu.thread_name_index = 0;
>>>         break;
>>> +    case RTEMS_RECORD_INTERRUPT_ENTRY:
>>> +      WriteIRQHandlerEntry(&pcpu, item);
>>> +      break;
>>> +    case RTEMS_RECORD_INTERRUPT_EXIT:
>>> +      WriteIRQHandlerExit(&pcpu, item);
>> ... then take the address of? I prefer to see references being used where
>> possible.
> This is the Google style:
> https://google.github.io/styleguide/cppguide.html#Reference_Arguments
> I think it makes sense. You see right at the calling place, that a parameter may
> be modified.
I do not agree, they forgot to discuss the help the compiler gives you and so I
will not adopt it. The Con has "... as they have value syntax but pointer
semantics" which is being little simplistic. I could go on but will not it is
style and may be related to a large existing code base and that may carry real
weight.
