[rtems commit] Add a parallel bootstrap command.
Thu Sep 5 13:11:14 UTC 2019
Hello Joel,
I may have time to work on a new build system later this year. So, I would not put too much work into the existing solutions.
----- Am 5. Sep 2019 um 14:51 schrieb joel joel at rtems.org:
> Hi
> Any chance, the parallel version will ever functionally replace bootstrap?
> It needs -c to clean and -H for headers.am.
> If we want to support exactly the same arguments (I don't care beyond
> functionality).
> usage: bootstrap [-c|-h|-H] [-q][-v]
> options:
>        -c .. clean, remove all aclocal/autoconf/automake generated files
>        -h .. display this message and exit
>        -H .. regenerate headers.am files
>        -q .. quiet, don't display directories
>        -v .. verbose, pass -v to autotools
> It would be nice to reduce the bootstrap programs.
