rtems-addr2line not working on ARM?
Fri Sep 6 09:09:21 UTC 2019
On 06/09/2019 09:26, Sebastian Huber wrote:
> On 06/09/2019 09:01, Chris Johns wrote:
>> On 6/9/19 4:20 pm, Sebastian Huber wrote:
>>> Hello,
>>> I tried the rtems-addr2line on ARM and SPARC. On SPARC it seems to
>>> work fine,
>>> however, on ARM I get this:
>>> rtems-addr2line -e
>>> build/arm-rtems5-xilinx_zynq_a9_qemu-everything/media01.exe
>>> 0x0000135a
>>> /home/EB/sebastian_h/git-rtems-5/c/src/lib/libbsp/arm/xilinx-zynq/../../../../../../bsps/arm/shared/irq/irq-gic.c:264
>>> addr2line -e
>>> build/arm-rtems5-xilinx_zynq_a9_qemu-everything/media01.exe 0000135a
>>> /scratch/git-rtems-libbsd/build/arm-rtems5-xilinx_zynq_a9_qemu-everything/../../testsuite/include/rtems/bsd/test/default-network-init.h:179
>>> The GNU tool is right. It is also considerably faster.
>> I would hope it is faster and exact. It has had many years of work on it,
>> written in C and not a means to test a C++ framework so we can grow an
>> ecosystem. I have stated its purpose before. I am perplexed by the
>> intent of
>> this statement.
>> If you want to compare performance I suggest you try the elftools one?
>> There is
>> one. It is not built because GNU provides one and good one.
>> Also be-careful as the exec call is not as fast as Linux on all the
>> hosts we
>> support.
> That the GNU tool is faster was just an observation.
> Do we have a working library solution to get from an address to the
> source line/function? I don't have time to debug the DWARF support code
> at the moment.
> I have a working solution using "addr2line" and rld::process::execute().
Thanks for the hint to the elftoolchain:
https://github.com/elftoolchain/elftoolchain/blob/trunk/addr2line/addr2line.c
To me it looks pretty complicated. It should be possible to refactor
this code to use it as a library, e.g. call translate() for each address
you need the source information.
I tried to debug the rld get_source() problem for more than two hours
and the elftoolchain code looks similar. I am not sure what to do.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
