MrsP Testbed
Wed Sep 11 04:56:59 UTC 2019
On 10/09/2019 15:56, Ricardo Gomes (1161078) wrote:
> In this email I sending one test for you to review it and see if it is
> structured according to RTEMS coding conventions, that I tried to fulfill.
> This test case is very simple, testing only if it is possible to set one
> priority per scheduling instance and also verifying if, when a task
> attempt to obtain a MrsP semaphore, its priority is immediately raised
> to the ceiling priority defined on its scheduler.
I am currently quite busy. Please remind me in one week. Could you
please change the licence to:
https://git.rtems.org/rtems/tree/LICENSE.BSD-2-Clause
Please send a complete patch so that I can build your test case and run it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
