[RTEMS][PATCH v2 0/2] riscv: add freedom E310 Arty A7
Pragnesh Patel pragnesh.patel at sifive.com
Wed Sep 11 08:43:05 UTC 2019
Ok understood.
If i will add Freedom E310 related code in bsp/riscv/riscv directory
then there are some code changes related to "console, btimer and other
minor things" so can i add this changes under new #define let's say
#define RISCV_ENABLE_FRDME310_SUPPORT ?
I am planning to add this #define in configure.ac through
RTEMS_BSPOPTS_SET([RISCV_ENABLE_FRDME310_SUPPORT],[*],[1]), By default
it is disabled.
what's your suggestion on this?
-Pragnesh
On Wed, Sep 11, 2019 at 1:03 PM Sebastian Huber
> On 11/09/2019 09:27, Pragnesh Patel wrote:
> > Thanks for the clarification. i am also agree with your comments but
> > let's say in future, we want to add I2C and SPI for Freedom E310 then
> > what's your suggestion?
> Future I2C and SPI drivers should be added to:
> https://git.rtems.org/rtems/tree/cpukit/dev
> They should be initialized in a BSP for example through the device tree.
> Currently, we lack a proper generic initialization via the device tree.
