[PATCH] Add lvgl_hello: Sample Hello world app using littleVGL and libbsd
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Sep 12 09:07:27 UTC 2019
On 12/09/2019 10:28, Vijay Kumar Banerjee wrote:
> On Wed, Sep 11, 2019 at 4:38 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     On 11/09/2019 10:48, Vijay Kumar Banerjee wrote:
>     >  Hi,
>     > Since adding I2C in BBB initialization seems like the right solution,
>     > should we ask
>     > in devel and user lists in a separate thread, to know if anyone is
>     > opposed to this change?
>     Hello Vijay,
>     just send a patch. That will start the discussion if someone objects
>     to it.
>     > Where should I be looking for to add i2c in BBB initialization?
>     Please take a look at the dependencies. If there are any (like clocks or
>     similar) you have to add it afterwards.
>     Take a look at some other BSPs where similar hardware (like I2C, SPI,
>     some external chips, ...) is initialized. For example the mvme3100 uses
>     a RTEMS_SYSINIT_ITEM to pick a random sample. But I think most BSPs use
>     a special init function similar to the one in BBB.
> Hi,
> I tried a very similar approach and added RTEMS_SYSINIT_ITEM
> diff --git a/bsps/arm/beagle/start/bspstart.c
> b/bsps/arm/beagle/start/bspstart.c
> index 224f9ecf3b..35839e774b 100644
> --- a/bsps/arm/beagle/start/bspstart.c
> +++ b/bsps/arm/beagle/start/bspstart.c
> @@ -17,6 +17,8 @@
>  #include <bsp/irq-generic.h>
>  #include <bsp/fdt.h>
>  #include <bsp/linker-symbols.h>
> +#include <bsp/i2c.h>
> +#include <rtems/sysinit.h>
>  #include "bspdebug.h"
> @@ -41,3 +43,15 @@ uint32_t bsp_fdt_map_intr(const uint32_t *intr,
> size_t icells)
>    return intr[0];
> +static void bbb_i2c_0_initialize(void)
> +  bbb_register_i2c_0();
> +RTEMS_SYSINIT_ITEM(
> +  bbb_i2c_0_initialize,
> +  RTEMS_SYSINIT_BSP_PRE_DRIVERS,
> +  RTEMS_SYSINIT_ORDER_MIDDLE
> This is successfully calling the `am335x_i2c_bus_register` but
> the issue with this approach is that it's returning the following
> internal error after `am335x_i2c_reset` call.
> _Terminate (the_source=the_source at entry=INTERNAL_ERROR_CORE,
> the_error=the_error at entry=30)
> Any hint on what might be the cause of the error?
Just a guess: Are you sure that "BSP_PRE_DRIVERS" is the right order?
It's a driver so maybe somewhen during the drivers?
Does bbb_i2c_0_initialize has a type that is compatible with the sysinit
items?
>     Best regards
>     Christian
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
