[PATCH] Correct initial POSIX signals mask
Thu Sep 12 13:05:58 UTC 2019
On 11/09/2019 01:11, Joel Sherrill wrote:
> +  if (!_System_state_Is_up(_System_state_Get())) {
> +    if (_Objects_Get_API(created->Object.id) == OBJECTS_INTERNAL_API) {
You have to add a couple of spaces to meet the coding style.
I would not use the system state, this could be a bit brittle on SMP
systems. Can't you use the executing thread instead, e.g. if
_Objects_Get_API( executing->Object.id ) == OBJECTS_INTERNAL_API, then
api->signals_unblocked = SIGNAL_ALL_MASK?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
