[PATCH] Correct initial POSIX signals mask
Thu Sep 12 14:12:37 UTC 2019
On Thu, Sep 12, 2019 at 8:06 AM Sebastian Huber
> On 11/09/2019 01:11, Joel Sherrill wrote:
> > +  if (!_System_state_Is_up(_System_state_Get())) {
> > +    if (_Objects_Get_API(created->Object.id) == OBJECTS_INTERNAL_API) {
> You have to add a couple of spaces to meet the coding style.
Gotcha.
> I would not use the system state, this could be a bit brittle on SMP
> systems. Can't you use the executing thread instead, e.g. if
> _Objects_Get_API( executing->Object.id ) == OBJECTS_INTERNAL_API, then
> api->signals_unblocked = SIGNAL_ALL_MASK?
I have changed it to
   if created == internal
     block all
   else if executing == internal
     unblock all for init threads/tasks
   else
     inherit
All tasks pass and I think this logic is correct.
V2 will be posted shortly.
Thanks for the comments.
--joel
