[PATCH v2] Correct initial POSIX signals mask
Thu Sep 12 14:41:40 UTC 2019
	+ Modify POSIX thread create extension to ensure expected
	  initial signal mask is provided to system threads, initial
	  tasks and threads, and inheritied by tasks and threads.
	+ Adds psxsignal07 to verify functionality when using a POSIX
	  Initialization thread and POSIX threads.
	+ Adds psxsignal08 to verify functionality when using a Classic API
	  Initialization task and Classic API tasks.
Closes #3794.
 cpukit/posix/src/pthreadcreate.c                |  53 +++++++-
 testsuites/psxtests/Makefile.am                 |  22 ++++
 testsuites/psxtests/configure.ac                |   2 +
 testsuites/psxtests/psxsignal01/init.c          |  14 ++
 testsuites/psxtests/psxsignal02/init.c          |  14 ++
 testsuites/psxtests/psxsignal03/init.c          |  14 ++
 testsuites/psxtests/psxsignal07/main.c          | 136 ++++++++++++++++++++
 testsuites/psxtests/psxsignal07/psxsignal07.doc |  23 ++++
 testsuites/psxtests/psxsignal07/psxsignal07.scn |   7 +
 testsuites/psxtests/psxsignal07/rtems_config.c  |  44 +++++++
 testsuites/psxtests/psxsignal08/main.c          | 163 ++++++++++++++++++++++++
 testsuites/psxtests/psxsignal08/psxsignal08.doc |  22 ++++
 testsuites/psxtests/psxsignal08/psxsignal08.scn |   7 +
 testsuites/psxtests/psxsignal08/rtems_config.c  |  45 +++++++
 14 files changed, 561 insertions(+), 5 deletions(-)
 create mode 100644 testsuites/psxtests/psxsignal07/main.c
 create mode 100644 testsuites/psxtests/psxsignal07/psxsignal07.doc
 create mode 100644 testsuites/psxtests/psxsignal07/psxsignal07.scn
 create mode 100644 testsuites/psxtests/psxsignal07/rtems_config.c
 create mode 100644 testsuites/psxtests/psxsignal08/main.c
 create mode 100644 testsuites/psxtests/psxsignal08/psxsignal08.doc
 create mode 100644 testsuites/psxtests/psxsignal08/psxsignal08.scn
 create mode 100644 testsuites/psxtests/psxsignal08/rtems_config.c
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 211b2cf..93e6fd8 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -86,7 +86,6 @@ int pthread_create(
   int                                 low_prio;
   Priority_Control                    core_low_prio;
   POSIX_API_Control                  *api;
-  const POSIX_API_Control            *executing_api;
 #endif
   if ( !start_routine )
@@ -260,9 +259,6 @@ int pthread_create(
    *  finish initializing the per API structure
   api = the_thread->API_Extensions[ THREAD_API_POSIX ];
-  executing_api = executing->API_Extensions[ THREAD_API_POSIX ];
-  api->signals_unblocked = executing_api->signals_unblocked;
   _Priority_Node_set_priority( &api->Sporadic.Low_priority, core_low_prio );
   api->Sporadic.sched_ss_repl_period =
@@ -376,7 +372,7 @@ void _POSIX_Threads_Sporadic_budget_callout( Thread_Control *the_thread )
 static bool _POSIX_Threads_Create_extension(
-  Thread_Control *executing RTEMS_UNUSED,
+  Thread_Control *executing,
   Thread_Control *created
@@ -389,6 +385,53 @@ static bool _POSIX_Threads_Create_extension(
   _Watchdog_Initialize( &api->Sporadic.Timer, _POSIX_Threads_Sporadic_timer );
   _Priority_Node_set_inactive( &api->Sporadic.Low_priority );
+#if defined(RTEMS_POSIX_API)
+   * There are some subtle rules which need to be followed for
+   * the value of the created thread's signal mask. Because signals
+   * are part of C99 and enhanced by POSIX, both Classic API tasks
+   * and POSIX threads have to have them enabled.
+   * + Internal system threads should have no signals enabled. They
+   *   have no business executing user signal handlers -- especially IDLE.
+   * + The initial signal mask for other threads needs to follow the
+   *   implication of a pure C99 environment which only has the methods
+   *   raise() and signal(). This implies that all signals are unmasked
+   *   until the thread explicitly uses a POSIX methods to block some.
+   *   This applies to both Classic tasks and POSIX threads created
+   *   as initalization tasks/threads (e.g. before the system is up).
+   * + After the initial threads are created, the signal mask should
+   *   be inherited from the creator.
+   * NOTE: The default signal mask does not matter for any application
+   *       that does not use POSIX signals.
+  if ( _Objects_Get_API(created->Object.id) == OBJECTS_INTERNAL_API ) {
+       * Ensure internal (especially IDLE) is handled first.
+       * Block signals for all internal threads -- especially IDLE.
+      api->signals_unblocked = 0;
+  } else if ( _Objects_Get_API(executing->Object.id) == OBJECTS_INTERNAL_API ) {
+       * Threads being created while an internal thread is executing
+       * should only happen for the initialization threads/tasks.
+       * Default state (signals unblocked) for all Initialization tasks
+       * and POSIX threads. We should not inherit from IDLE which is
+       * what appears to be executing during initialization.
+      api->signals_unblocked = SIGNAL_ALL_MASK;
+  } else {
+    const POSIX_API_Control            *executing_api;
+     * RTEMS is running so follow the POSIX rules to inherit the signal mask.
+    executing_api = executing->API_Extensions[ THREAD_API_POSIX ];
+    api->signals_unblocked = executing_api->signals_unblocked;
+#endif
   return true;
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 2ccb10a..536b77f 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -881,6 +881,28 @@ psxsignal06_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal06) \
 endif
 endif
+if HAS_POSIX
+if TEST_psxsignal07
+psx_tests += psxsignal07
+psx_screens += psxsignal07/psxsignal07.scn
+psx_docs += psxsignal07/psxsignal07.doc
+psxsignal07_SOURCES = psxsignal07/main.c psxsignal07/rtems_config.c
+psxsignal07_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal07) \
+	$(support_includes) -I$(top_srcdir)/include
+endif
+endif
+if HAS_POSIX
+if TEST_psxsignal08
+psx_tests += psxsignal08
+psx_screens += psxsignal08/psxsignal08.scn
+psx_docs += psxsignal08/psxsignal08.doc
+psxsignal08_SOURCES = psxsignal08/main.c psxsignal08/rtems_config.c
+psxsignal08_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal08) \
+endif
+endif
 if TEST_psxspin01
 psx_tests += psxspin01
 psx_screens += psxspin01/psxspin01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 6e2b19f..139787c 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -135,6 +135,8 @@ RTEMS_TEST_CHECK([psxsignal03])
 RTEMS_TEST_CHECK([psxsignal04])
 RTEMS_TEST_CHECK([psxsignal05])
 RTEMS_TEST_CHECK([psxsignal06])
+RTEMS_TEST_CHECK([psxsignal07])
+RTEMS_TEST_CHECK([psxsignal08])
 RTEMS_TEST_CHECK([psxspin01])
 RTEMS_TEST_CHECK([psxstack01])
 RTEMS_TEST_CHECK([psxstack02])
diff --git a/testsuites/psxtests/psxsignal01/init.c b/testsuites/psxtests/psxsignal01/init.c
index 511dd2d..6df3695 100644
--- a/testsuites/psxtests/psxsignal01/init.c
+++ b/testsuites/psxtests/psxsignal01/init.c
@@ -36,6 +36,18 @@ extern void _POSIX_signals_Abnormal_termination_handler( int signo );
 volatile int Signal_occurred;
 volatile int Signal_count;
+static void block_all_signals(void)
+  int               sc;
+  sigset_t          mask;
+  sc = sigfillset( &mask );
+  rtems_test_assert( !sc );
+  sc = pthread_sigmask( SIG_BLOCK, &mask, NULL );
 void Handler_1(
   int signo
@@ -108,6 +120,8 @@ void *POSIX_Init(
   TEST_BEGIN();
+  block_all_signals();
   /* set the time of day, and print our buffer in multiple ways */
   set_time( TM_FRIDAY, TM_MAY, 24, 96, 11, 5, 0 );
diff --git a/testsuites/psxtests/psxsignal02/init.c b/testsuites/psxtests/psxsignal02/init.c
index 1f9afc9..c7a9432 100644
--- a/testsuites/psxtests/psxsignal02/init.c
+++ b/testsuites/psxtests/psxsignal02/init.c
@@ -28,6 +28,18 @@ void Install_Signal_Handler(const char *task_name);
 volatile bool      Signal_occurred;
 volatile pthread_t Signal_thread;
+  int               sc;
+  sigset_t          mask;
 void Signal_handler(
   int signo
@@ -140,6 +152,8 @@ void *POSIX_Init(
   Signal_occurred = false;
   act.sa_handler = Signal_handler;
   act.sa_flags   = 0;
   sigaction( SIGUSR1, &act, NULL );
diff --git a/testsuites/psxtests/psxsignal03/init.c b/testsuites/psxtests/psxsignal03/init.c
index b51ff36..fcf7192 100644
--- a/testsuites/psxtests/psxsignal03/init.c
+++ b/testsuites/psxtests/psxsignal03/init.c
@@ -64,6 +64,18 @@ const char *signal_name(int signo);
+  int               sc;
+  sigset_t          mask;
   int        signo,
   siginfo_t *info,
@@ -166,6 +178,8 @@ void *POSIX_Init(
   TEST_BEGIN();
   puts( "Init - Variation is: " TEST_STRING );
   act.sa_handler = NULL;
diff --git a/testsuites/psxtests/psxsignal07/main.c b/testsuites/psxtests/psxsignal07/main.c
new file mode 100644
index 0000000..52b2175
--- /dev/null
+++ b/testsuites/psxtests/psxsignal07/main.c
@@ -0,0 +1,136 @@
+ * @brief psxsignal07 - Ensure initial signal mask and thread inheritance
+ * COPYRIGHT (c) 2019.
+ * On-Line Applications Research Corporation (OAR).
+ * SPDX-License-Identifier: BSD-2-Clause
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <tmacros.h>
+#include "test_support.h"
+#include <errno.h>
+#include <pthread.h>
+#include <signal.h>
+const char rtems_test_name[] = "PSXSIGNAL 7";
+static sigset_t main_sigmask;
+#define SIGSET_NBYTES (sizeof(sigset_t))
+/* #define DEBUG_TEST */
+static void fetch_sigmask(const char *name, sigset_t *sigset_p)
+  int   rc;
+  rc = sigemptyset(sigset_p);
+  rtems_test_assert(rc == 0);
+  rc = sigprocmask(SIG_SETMASK, NULL, sigset_p);
+#ifdef DEBUG_TEST
+   * There is no assurance that sigset_t is a primitive type so
+   * we have to print it a long at a time.
+  int            i;
+  unsigned char *p = (unsigned char *) sigset_p;
+  printf("%s signal mask (in hex):\n    ", name);
+  for (i=0 ; i < SIGSET_NBYTES ; i++) {
+    printf("%02x%s", *p++, (i % 16 == 15) ? "\n    " : " ");
+  printf("\n");
+#endif
+static void block_sigmask(int signo, sigset_t *sigset_p)
+  sigset_t sigset;
+  int      rc;
+   * Block the requested signal
+  rc = sigemptyset(&sigset);
+  rc = sigaddset(&sigset, signo);
+  rc = sigprocmask(SIG_BLOCK, &sigset, NULL);
+   * Fetch the current signal mask reflecting the requested update
+  sigemptyset(sigset_p);
+static void *thread_body(void *arg)
+  sigset_t    mask;
+   * we have to use memcmp().
+  fetch_sigmask("main", &main_sigmask);
+  fetch_sigmask(arg, &mask);
+  rtems_test_assert(main_sigmask == mask);
+  return NULL;
+int main(int argc, char **argv)
+  int        rc;
+  pthread_t  id;
+  sigset_t   empty;
+  TEST_BEGIN();
+   * Verify first thread has empty signal mask
+  sigemptyset(&empty);
+  fetch_sigmask("empty", &empty);
+  puts("Ensure main thread's mask equals sigemptyset");
+  rtems_test_assert(main_sigmask == empty);
+  puts("Ensure parent's empty mask is inherited by thread");
+  rc = pthread_create(&id, NULL, thread_body, "thread1");
+  sleep(1);
+   * Create a thread and see if it inherits non-empty signal mask.
+  puts("Ensure parent's mask with SIGUSR1 mask is inherited by thread");
+  block_sigmask(SIGUSR1, &main_sigmask);
+  rc = pthread_create(&id, NULL, thread_body, "thread2");
+  sleep(1);
+  TEST_END();
+  rtems_test_exit(0);
+  return 0;
diff --git a/testsuites/psxtests/psxsignal07/psxsignal07.doc b/testsuites/psxtests/psxsignal07/psxsignal07.doc
index 0000000..7842547
--- /dev/null
+++ b/testsuites/psxtests/psxsignal07/psxsignal07.doc
@@ -0,0 +1,23 @@
+#  COPYRIGHT (c) 2019.
+#  On-Line Applications Research Corporation (OAR).
+#  SPDX-License-Identifier: BSD-2-Clause
+This file describes the directives and concepts tested by this test set.
+test set name:  psxsignal07
+directives:
+  sigprocmask
+  sigemptyset
+  sigaddset
+concepts:
++ Ensure that the initial signal mask is empty (all unmasked).
++ Ensure that a POSIX thread inherits an empty signal mask.
++ Ensure that a POSIX thread inherits an non-empty signal mask.
diff --git a/testsuites/psxtests/psxsignal07/psxsignal07.scn b/testsuites/psxtests/psxsignal07/psxsignal07.scn
index 0000000..ad7a12d
--- /dev/null
+++ b/testsuites/psxtests/psxsignal07/psxsignal07.scn
@@ -0,0 +1,7 @@
+*** BEGIN OF TEST PSXSIGNAL 7 ***
+Ensure main thread's mask equals sigemptyset
+Ensure parent's empty mask is inherited by thread
+Ensure parent's mask with SIGUSR1 mask is inherited by thread
+*** END OF TEST PSXSIGNAL 7 ***
diff --git a/testsuites/psxtests/psxsignal07/rtems_config.c b/testsuites/psxtests/psxsignal07/rtems_config.c
index 0000000..e3f3349
--- /dev/null
+++ b/testsuites/psxtests/psxsignal07/rtems_config.c
@@ -0,0 +1,44 @@
+#include <stdlib.h>
+int main(int argc, char **argv);
+static char *argv_list[] = {
+  "psxsignal07",
+static void *POSIX_Init(void *arg)
+  (void) arg;  /* deliberately ignored */
+   * Initialize optional services
+   * Could get arguments from command line or have a static set.
+  (void) main(1, argv_list);
+  return NULL;
+#include <bsp.h> /* for device driver prototypes */
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxsignal08/main.c b/testsuites/psxtests/psxsignal08/main.c
index 0000000..c55a771
--- /dev/null
+++ b/testsuites/psxtests/psxsignal08/main.c
@@ -0,0 +1,163 @@
+ * @brief psxsignal08 - Ensure initial signal mask and Classic Task inheritance
+#endif
+#include <errno.h>
+#include <unistd.h>
+#include <rtems.h>
+const char rtems_test_name[] = "PSXSIGNAL 8";
+  int   rc;
+#ifdef DEBUG_TEST
+  int            i;
+  printf("\n");
+#endif
+  sigset_t sigset;
+  int      rc;
+static rtems_task task_body(rtems_task_argument arg)
+  sigset_t    mask;
+  fetch_sigmask((void *)arg, &mask);
+  (void) rtems_task_delete(RTEMS_SELF);
+  sigset_t          empty;
+  rtems_status_code status;
+  rtems_id          id;
+  TEST_BEGIN();
+   * Verify first task has empty signal mask
+  puts("Ensure main task's mask equals sigemptyset");
+   * Create a task and see if it inherits empty signal mask.
+  status = rtems_task_create(
+    rtems_build_name( 'T', 'A', '1', ' ' ),
+    1,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &id
+  directive_failed( status, "rtems_task_create" );
+  status = rtems_task_start( id, task_body, 1 );
+  directive_failed( status, "rtems_task_start" );
+  sleep(1);
+   * Create a task and see if it inherits non-empty signal mask.
+    1,
+    &id
+  sleep(1);
+  TEST_END();
+  return 0;
diff --git a/testsuites/psxtests/psxsignal08/psxsignal08.doc b/testsuites/psxtests/psxsignal08/psxsignal08.doc
index 0000000..f476996
--- /dev/null
+++ b/testsuites/psxtests/psxsignal08/psxsignal08.doc
@@ -0,0 +1,22 @@
+directives:
+  sigprocmask
+  sigemptyset
+  sigaddset
+concepts:
++ Ensure that a Classic API task inherits an empty signal mask.
++ Ensure that a Classic API task inherits an non-empty signal mask.
diff --git a/testsuites/psxtests/psxsignal08/psxsignal08.scn b/testsuites/psxtests/psxsignal08/psxsignal08.scn
index 0000000..6aa8ce8
--- /dev/null
+++ b/testsuites/psxtests/psxsignal08/psxsignal08.scn
@@ -0,0 +1,7 @@
+** BEGIN OF TEST PSXSIGNAL 8 ***
+Ensure main task's mask equals sigemptyset
+*** END OF TEST PSXSIGNAL 8 ***
diff --git a/testsuites/psxtests/psxsignal08/rtems_config.c b/testsuites/psxtests/psxsignal08/rtems_config.c
index 0000000..f56e88c
--- /dev/null
+++ b/testsuites/psxtests/psxsignal08/rtems_config.c
@@ -0,0 +1,45 @@
+#include <rtems.h>
+  "report",
+static rtems_task Init(rtems_task_argument arg)
+  exit(0);
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
1.8.3.1
