Trying to interrupt a blocking read...
Benjamin Ellsworth 2GigSpamBucket at gmail.com
Fri Sep 13 00:33:29 UTC 2019
It appears that VTIME does not work.  I set both VMIN and VTIME and I
never get a timeout.  The read continues to happily block forever.
Also, when looking at VTIME handling down in the code, I see in
termios.c the function fillBufferPoll().  It looks to me like that
function expects (*tty->handler.poll_read) to return in less than
tty->vtimeTicks in every case.  I don't see how that is guaranteed.
If (*tty->handler.poll_read) blocks until a byte shows up, then VTIME is
basically meaningless.  I don't see any code that sends VTIME or
vtimeTicks down to the underlying handler, so I don't see how the
timeout could possibly be honored.
Or maybe there's something I don't understand...
Here is the function:
static void
fillBufferPoll (struct rtems_termios_tty *tty)
   int n;
   if (tty->termios.c_lflag & ICANON) {
     for (;;) {
       n = (*tty->handler.poll_read)(tty->device_context);
       if (n < 0) {
         rtems_task_wake_after (1);
       } else {
         if  (siprocPoll (n, tty))
           break;
   } else {
     rtems_interval then, now;
     then = rtems_clock_get_ticks_since_boot();
     for (;;) {
       if (n < 0) {
         if (tty->termios.c_cc[VMIN]) {
           if (tty->termios.c_cc[VTIME] && tty->ccount) {
             now = rtems_clock_get_ticks_since_boot();
             if ((now - then) > tty->vtimeTicks) {
               break;
         } else {
           if (!tty->termios.c_cc[VTIME])
             break;
             break;
       } else {
         siprocPoll (n, tty);
         if (tty->ccount >= tty->termios.c_cc[VMIN])
           break;
         if (tty->termios.c_cc[VMIN] && tty->termios.c_cc[VTIME])
Or, maybe there's something I don't understand...
Thanks.
On 10-Sep-19 10:18 AM, Joel Sherrill wrote:
> On Tue, Sep 10, 2019 at 12:09 AM Benjamin Ellsworth
> <2gigspambucket at gmail.com> wrote:
>> Hello,
>> The code I'm working with currently does a read() on a device that has
>> been opened with an open() call (a UART if that matters).  It nicely
>> blocks waiting for a character (potentially forever).
>> I now need that read to be interrupted...  I looked for pselect() so it
>> can block until I tell it to stop (via signal from another thread), but
>> that doesn't seem to be supported.  I looked at the classic work-around
>> using a pipe in a select call, but pipe() isn't supported and select
>> apparently only works on sockets (and the comments in the select header
>> make it sound like even that is a bad idea).
> What version? I thought select() on termios devices was added at least
> to the master.
> You are right that it historically hasn't worked.
> pipe() is supported. psxpipe01 is the test. Not sure about the use case
> you have in mind.
>> I can probably make things work with timeouts--basically making it into
>> a polling loop, but I can't see a way to make the read timeout.  I dug
>> down into the rtems read functions, but didn't see any way to make them
>> timeout, nor did I see a way to cleanly interrupt them.
> read() on a UART should be able to do non-blocking or timeout on read()
> with the VMIN and VTIME support from termios. There should be examples
> of this around the net.
>> If anyone has any suggestions/ideas/pointers, I'd appreciate them.
> --joel
>> Thanks.
>> devel mailing list
>> devel at rtems.org
