LLVM on openSUSE 15.1
Tue Sep 17 06:10:37 UTC 2019
On 17/09/2019 08:07, Sebastian Huber wrote:
> On 17/09/2019 08:07, Chris Johns wrote:
>> On 17/9/19 3:32 pm, Sebastian Huber wrote:
>>> Hello,
>>> I didn't get far:
>>> config.status: creating t/wrap/automake-1.12
>>> + make -j 12 all
>>>    GEN      automake
>>>    GEN      aclocal
>>>    GEN      t/ax/shell-no-trail-bslash
>>>    GEN      doc/aclocal.1
>>>    GEN      doc/automake.1
>>>    GEN      runtest
>>>    GEN      t/ax/test-defs.sh
>>>    GEN      lib/Automake/Config.pm
>>>    GEN      doc/aclocal-1.12.1
>>>    GEN      doc/automake-1.12.1
>>> help2man: can't get `--help' info from automake-1.12
>>> Try `--no-discard-stderr' if option outputs to stderr
>>> make: *** [Makefile:4114: doc/automake-1.12.1] Error 255
>> That is weird because this is what we build for gcc as we need
>> autoconf to boot
>> strap RTEMS.
> This is indeed quite weird, I never had problems building automake
> before. I will try to figure out what went wrong here.
Building it for a normal RTEMS package works fine:
../source-builder/sb-set-builder --prefix=/build/rtems/5 5/rtems-riscv
--no-install
RTEMS Source Builder - Set Builder, 5 (4b7af073000d modified)
warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
Build Set: 5/rtems-riscv
Build Set: 5/rtems-autotools.bset
Build Set: 5/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-linux-gnu-1
building: autoconf-2.69-x86_64-linux-gnu-1
sizes: autoconf-2.69-x86_64-linux-gnu-1: 7.497MB (installed: 0.000B)
cleaning: autoconf-2.69-x86_64-linux-gnu-1
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-x86_64-linux-gnu-1
building: automake-1.12.6-x86_64-linux-gnu-1
sizes: automake-1.12.6-x86_64-linux-gnu-1: 8.088MB (installed: 0.000B)
cleaning: automake-1.12.6-x86_64-linux-gnu-1
Build Sizes: usage: 8.088MB total: 7.774GB (sources: 7.772GB, patches:
1.957MB, installed 0.000B)
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
