[PATCH] update rtems_waf
Christian Mauderer list at c-mauderer.de
Tue Sep 17 08:49:07 UTC 2019
On 17/09/2019 08:51, Vijay Kumar Banerjee wrote:
> On Fri, Sep 13, 2019 at 9:00 AM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 11/9/19 6:14 pm, Vijay Kumar Banerjee wrote:
>     > ping :)
>     Sorry about the delay. OK to push.
> Hi,
> Thanks for the review!
> Can you please push this. :)
Pushed it.
> Also, the github descript for rtems-examples has the wrong link,
> it needs to be updated to https://git.rtems.org/rtems-examples.
I don't have access to these. So I can't update it. Chris: Do you have
access?
> Best regards,
> Vijay>
>     Chris
>     > On Tue, Sep 3, 2019 at 7:04 PM Vijay Kumar Banerjee
>     <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>
>     <mailto:vijaykumar9597 at gmail.com>>> wrote:
>     >      file_io/crc/wscript            | 6 +++---
>     >      filesystem/fat_ramdisk/wscript | 6 +++---
>     >      rtems_waf                      | 2 +-
>     >      3 files changed, 7 insertions(+), 7 deletions(-)
>     >     diff --git a/file_io/crc/wscript b/file_io/crc/wscript
>     >     index f7b0f5b..531da20 100644
>     >     --- a/file_io/crc/wscript
>     >     +++ b/file_io/crc/wscript
>     >     @@ -26,9 +26,9 @@ def build(bld):
>     >          # Package the root file system as a C file.
>     >     -    rootfs.build(bld,
>     >     -                 name = 'fs-root',
>     >     -                 root = 'rootfs')
>     >     +    rootfs.build_from_src_root(bld,
>     >     +                               name = 'fs-root',
>     >     +                               root = 'rootfs')
>     >          bld(features = 'c cprogram',
>     >              target = 'crc.exe',
>     >     diff --git a/filesystem/fat_ramdisk/wscript
>     b/filesystem/fat_ramdisk/wscript
>     >     index de806c1..a980187 100644
>     >     --- a/filesystem/fat_ramdisk/wscript
>     >     +++ b/filesystem/fat_ramdisk/wscript
>     >     -    rootfs.build(bld,
>     >     -                 name = 'fs-root',
>     >     -                 root = 'rootfs')
>     >     +                               name = 'fs-root',
>     >     +                               root = 'rootfs')
>     >              target = 'fat_ramdisk.exe',
>     >     diff --git a/rtems_waf b/rtems_waf
>     >     index 1b89636..ad6c6e8 160000
>     >     --- a/rtems_waf
>     >     +++ b/rtems_waf
>     >     @@ -1 +1 @@
>     >     -Subproject commit 1b896361d302aeda0145af90972aea863e28898f
>     >     +Subproject commit ad6c6e8771b95dffa73a7dc1167d98d208f17cb0
>     >     2.20.1
