LLVM on openSUSE 15.1
Wed Sep 18 06:09:51 UTC 2019
On 18/09/2019 07:40, Chris Johns wrote:
> On 18/9/19 3:36 pm, Sebastian Huber wrote:
>> On 17/09/2019 08:07, Sebastian Huber wrote:
>>> On 17/09/2019 08:07, Chris Johns wrote:
>>>> On 17/9/19 3:32 pm, Sebastian Huber wrote:
>>>>> Hello,
>>>>> I didn't get far:
>>>>> config.status: creating t/wrap/automake-1.12
>>>>> + make -j 12 all
>>>>>     GEN      automake
>>>>>     GEN      aclocal
>>>>>     GEN      t/ax/shell-no-trail-bslash
>>>>>     GEN      doc/aclocal.1
>>>>>     GEN      doc/automake.1
>>>>>     GEN      runtest
>>>>>     GEN      t/ax/test-defs.sh
>>>>>     GEN      lib/Automake/Config.pm
>>>>>     GEN      doc/aclocal-1.12.1
>>>>>     GEN      doc/automake-1.12.1
>>>>> help2man: can't get `--help' info from automake-1.12
>>>>> Try `--no-discard-stderr' if option outputs to stderr
>>>>> make: *** [Makefile:4114: doc/automake-1.12.1] Error 255
>>>> That is weird because this is what we build for gcc as we need autoconf to boot
>>>> strap RTEMS.
>>> This is indeed quite weird, I never had problems building automake before. I
>>> will try to figure out what went wrong here.
>> We have configuration files for Automake 1.12.6. I fixed it like this:
>> https://git.rtems.org/rtems-source-builder/commit/?id=bf7b4ad68f0faa9a35e52ca1baafb6f72c0fb673
This change breaks the build of the RTEMS toolchain on FreeBSD 12.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
