LLVM on openSUSE 15.1
Wed Sep 18 08:29:15 UTC 2019
On 18/9/19 4:09 pm, Sebastian Huber wrote:
> On 18/09/2019 07:40, Chris Johns wrote:
>> On 18/9/19 3:36 pm, Sebastian Huber wrote:
>>> On 17/09/2019 08:07, Sebastian Huber wrote:
>>>> On 17/09/2019 08:07, Chris Johns wrote:
>>>>> On 17/9/19 3:32 pm, Sebastian Huber wrote:
>>>>>> Hello,
>>>>>> I didn't get far:
>>>>>> config.status: creating t/wrap/automake-1.12
>>>>>> + make -j 12 all
>>>>>>     GEN      automake
>>>>>>     GEN      aclocal
>>>>>>     GEN      t/ax/shell-no-trail-bslash
>>>>>>     GEN      doc/aclocal.1
>>>>>>     GEN      doc/automake.1
>>>>>>     GEN      runtest
>>>>>>     GEN      t/ax/test-defs.sh
>>>>>>     GEN      lib/Automake/Config.pm
>>>>>>     GEN      doc/aclocal-1.12.1
>>>>>>     GEN      doc/automake-1.12.1
>>>>>> help2man: can't get `--help' info from automake-1.12
>>>>>> Try `--no-discard-stderr' if option outputs to stderr
>>>>>> make: *** [Makefile:4114: doc/automake-1.12.1] Error 255
>>>>> That is weird because this is what we build for gcc as we need autoconf to
>>>>> boot
>>>>> strap RTEMS.
>>>> This is indeed quite weird, I never had problems building automake before. I
>>>> will try to figure out what went wrong here.
>>> We have configuration files for Automake 1.12.6. I fixed it like this:
>>> https://git.rtems.org/rtems-source-builder/commit/?id=bf7b4ad68f0faa9a35e52ca1baafb6f72c0fb673
> This change breaks the build of the RTEMS toolchain on FreeBSD 12.
I do not understand ...
https://lists.rtems.org/pipermail/build/2019-September/003517.html ?
