LLVM on openSUSE 15.1
Wed Sep 18 08:56:11 UTC 2019
On 18/9/19 6:35 pm, Sebastian Huber wrote:
> On 18/09/2019 10:29, Chris Johns wrote:
>> On 18/9/19 4:09 pm, Sebastian Huber wrote:
>>> On 18/09/2019 07:40, Chris Johns wrote:
>>>> On 18/9/19 3:36 pm, Sebastian Huber wrote:
>>>>> On 17/09/2019 08:07, Sebastian Huber wrote:
>>>>>> On 17/09/2019 08:07, Chris Johns wrote:
>>>>>>> On 17/9/19 3:32 pm, Sebastian Huber wrote:
>>>>>>>> Hello,
>>>>>>>> I didn't get far:
>>>>>>>> config.status: creating t/wrap/automake-1.12
>>>>>>>> + make -j 12 all
>>>>>>>>      GEN      automake
>>>>>>>>      GEN      aclocal
>>>>>>>>      GEN      t/ax/shell-no-trail-bslash
>>>>>>>>      GEN      doc/aclocal.1
>>>>>>>>      GEN      doc/automake.1
>>>>>>>>      GEN      runtest
>>>>>>>>      GEN      t/ax/test-defs.sh
>>>>>>>>      GEN      lib/Automake/Config.pm
>>>>>>>>      GEN      doc/aclocal-1.12.1
>>>>>>>>      GEN      doc/automake-1.12.1
>>>>>>>> help2man: can't get `--help' info from automake-1.12
>>>>>>>> Try `--no-discard-stderr' if option outputs to stderr
>>>>>>>> make: *** [Makefile:4114: doc/automake-1.12.1] Error 255
>>>>>>> That is weird because this is what we build for gcc as we need autoconf to
>>>>>>> boot
>>>>>>> strap RTEMS.
>>>>>> This is indeed quite weird, I never had problems building automake before. I
>>>>>> will try to figure out what went wrong here.
>>>>> We have configuration files for Automake 1.12.6. I fixed it like this:
>>>>> https://git.rtems.org/rtems-source-builder/commit/?id=bf7b4ad68f0faa9a35e52ca1baafb6f72c0fb673
>>> This change breaks the build of the RTEMS toolchain on FreeBSD 12.
>> I do not understand ...
>> https://lists.rtems.org/pipermail/build/2019-September/003517.html ?
> Building the unstable RTEMS 6 toolchain results in an endless build of automake
> with this patch on FreeBSD 12.
OK. I will have a look tomorrow.
