LLVM on openSUSE 15.1
Tue Sep 24 06:06:11 UTC 2019
Hello,
with the libedit development package mentioned by Gedare, I got a bit
further in the build:
onfig: tools/rtems-llvm-8.0.1.cfg
package: rtems-llvm-8.0.1-x86_64-linux-gnu-1
building: rtems-llvm-8.0.1-x86_64-linux-gnu-1
error: building rtems-llvm-8.0.1-x86_64-linux-gnu-1
Build FAILED
error: failure to create error report
Build Set: Time 0:34:28.127871
Traceback (most recent call last):
   File "../source-builder/sb/cmd-set-builder.py", line 26, in <module>
     setbuilder.run()
   File
"/scratch/git-rtems-source-builder/source-builder/sb/setbuilder.py",
line 732, in run
     b.build(deps, mail = mail)
   File
line 473, in build
     self.build_package(configs[s], b)
   File
line 258, in build_package
     _build.make()
   File "/scratch/git-rtems-source-builder/source-builder/sb/build.py",
line 579, in make
     self._generate_report_('Build: %s' % (gerr))
line 126, in _generate_report_
     self.opts, header, footer)
   File
"/scratch/git-rtems-source-builder/source-builder/sb/ereport.py", line
56, in generate
     l.write(os.linesep.join(r))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position
156: ordinal not in range(128)
The build error was:
/scratch/git-rtems-source-builder/rtems/build/rtems-llvm-8.0.1-x86_64-linux-gnu-1/llvm-8.0.1/tools/lldb/source/Core/IOHandler.cpp:14:10:
fatal error: panel.h: No such file or directory
  #include <panel.h>
compilation terminated.
This looks like an openSUSE problem:
https://build.opensuse.org/package/view_file/openSUSE:Leap:42.2/llvm/lldb-cmake.patch?expand=0
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
