[PATCH] update rtems_waf
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Thu Sep 5 10:01:01 UTC 2019
On Thu, Sep 5, 2019 at 3:00 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Hello Vijay,
> from the content I assume that's for rtems-examples.
> Out of curiosity: Is there some specific problem that is solved with
> that patch or is it just to be on the latest version? If there is a
> problem, it would be good to mention that in the commit message. If
> someone else has the same problem, he might be able to find the message
> and see that the commit solves it.
> Hi Christian,
The current build works fine, the intention behind updating is to use the
rtems_bsd checks that are present in the latest HEAD of rtems_waf. I was
using the new features in the lvgl example, but since that one has a pending
discussion, I sent a separate patch to just update the rtems_waf.
Best regards,
Vijay
> To be honest: I haven't really built the examples yet (maybe sometimes
> way back). So I won't be able to do a test of the patch in the next
> days. I hope that someone else will be able to test it till then so that
> it can be commited.
> Best regards
> Christian
> On 03/09/2019 15:33, Vijay Kumar Banerjee wrote:
> >  file_io/crc/wscript            | 6 +++---
> >  filesystem/fat_ramdisk/wscript | 6 +++---
> >  rtems_waf                      | 2 +-
> >  3 files changed, 7 insertions(+), 7 deletions(-)
> > diff --git a/file_io/crc/wscript b/file_io/crc/wscript
> > index f7b0f5b..531da20 100644
> > --- a/file_io/crc/wscript
> > +++ b/file_io/crc/wscript
> > @@ -26,9 +26,9 @@ def build(bld):
> >      # Package the root file system as a C file.
> > -    rootfs.build(bld,
> > -                 name = 'fs-root',
> > -                 root = 'rootfs')
> > +    rootfs.build_from_src_root(bld,
> > +                               name = 'fs-root',
> > +                               root = 'rootfs')
> >      bld(features = 'c cprogram',
> >          target = 'crc.exe',
> > diff --git a/filesystem/fat_ramdisk/wscript
> b/filesystem/fat_ramdisk/wscript
> > index de806c1..a980187 100644
> > --- a/filesystem/fat_ramdisk/wscript
> > +++ b/filesystem/fat_ramdisk/wscript
> > -    rootfs.build(bld,
> > -                 name = 'fs-root',
> > -                 root = 'rootfs')
> > +                               name = 'fs-root',
> > +                               root = 'rootfs')
> >          target = 'fat_ramdisk.exe',
> > diff --git a/rtems_waf b/rtems_waf
> > index 1b89636..ad6c6e8 160000
> > --- a/rtems_waf
> > +++ b/rtems_waf
> > @@ -1 +1 @@
> > -Subproject commit 1b896361d302aeda0145af90972aea863e28898f
> > +Subproject commit ad6c6e8771b95dffa73a7dc1167d98d208f17cb0
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190905/6b498c6d/attachment-0002.html>
