[rtems commit] Add a parallel bootstrap command.
Thu Sep 5 12:51:27 UTC 2019
Hi
Any chance, the parallel version will ever functionally replace bootstrap?
It needs -c to clean and -H for headers.am.
If we want to support exactly the same arguments (I don't care beyond
functionality).
usage: bootstrap [-c|-h|-H] [-q][-v]
options:
        -c .. clean, remove all aclocal/autoconf/automake generated files
        -h .. display this message and exit
        -H .. regenerate headers.am files
        -q .. quiet, don't display directories
        -v .. verbose, pass -v to autotools
It would be nice to reduce the bootstrap programs.
--joel
On Wed, Sep 4, 2019 at 11:29 PM Chris Johns <chrisj at rtems.org> wrote:
> Module:    rtems
> Branch:    master
> Commit:    02ed0b802bb49cb380bc1387dc85adca059babee
> Changeset: http://git.rtems.org/rtems/commit/?id=02ed0b802bb49cb380bc1387dc85adca059babee
> Author:    Chris Johns <chrisj at rtems.org>
> Date:      Tue Sep  3 10:40:46 2019 +1000
>  rtems-bootstrap | 246 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++
>  1 file changed, 246 insertions(+)
> diff --git a/rtems-bootstrap b/rtems-bootstrap
> new file mode 100755
> index 0000000..6519710
> --- /dev/null
> +++ b/rtems-bootstrap
> @@ -0,0 +1,246 @@
> +#! /usr/bin/env python
> +# SPDX-License-Identifier: BSD-2-Clause
> +# Copyright (C) 2013-2019 Chris Johns (chrisj at rtems.org)
> +# All rights reserved.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions
> +# are met:
> +# 1. Redistributions of source code must retain the above copyright
> +#    notice, this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> +#    notice, this list of conditions and the following disclaimer in the
> +#    documentation and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# RTEMS Tools Project (http://www.rtems.org/)
> +from __future__ import print_function
> +import argparse
> +import datetime
> +import multiprocessing
> +import os
> +import re
> +import sys
> +import threading
> +import time
> +version = "1.0"
> +class error(Exception):
> +    """Base class for Builder exceptions."""
> +    def set_output(self, msg):
> +        self.msg = msg
> +    def __str__(self):
> +        return self.msg
> +class general_error(error):
> +    """Raise for a general error."""
> +    def __init__(self, what):
> +        self.set_output('error: ' + str(what))
> +def _collect(path_, file):
> +    confs = []
> +    for root, dirs, files in os.walk(path_, topdown = True):
> +        for f in files:
> +            if f == file:
> +                confs += [os.path.join(root, f)]
> +    return confs
> +def _grep(file, pattern):
> +    rege = re.compile(pattern)
> +    try:
> +        f = open(file, 'r')
> +        matches = [rege.match(l) != None for l in f.readlines()]
> +        f.close()
> +    except IOError as err:
> +        raise general_error('reading: %s' % (file))
> +    return True in matches
> +class command:
> +    def __init__(self, cmd, cwd):
> +        self.exit_code = 0
> +        self.thread = None
> +        self.output = None
> +        self.cmd = cmd
> +        self.cwd = cwd
> +        self.result = None
> +    def runner(self):
> +        import subprocess
> +        # Support Python 2.6
> +        if "check_output" not in dir(subprocess):
> +            def f(*popenargs, **kwargs):
> +                if 'stdout' in kwargs:
> +                    raise ValueError('stdout argument not allowed, it will be overridden.')
> +                process = subprocess.Popen(stdout=subprocess.PIPE, *popenargs, **kwargs)
> +                output, unused_err = process.communicate()
> +                retcode = process.poll()
> +                if retcode:
> +                    cmd = kwargs.get("args")
> +                    if cmd is None:
> +                        cmd = popenargs[0]
> +                    raise subprocess.CalledProcessError(retcode, cmd)
> +                return output
> +            subprocess.check_output = f
> +        self.start_time = datetime.datetime.now()
> +        try:
> +            try:
> +                if os.name == 'nt':
> +                    cmd = ['sh', '-c'] + self.cmd
> +                else:
> +                    cmd = self.cmd
> +                self.output = subprocess.check_output(cmd, cwd = self.cwd)
> +            except subprocess.CalledProcessError as cpe:
> +                self.exit_code = cpe.returncode
> +                self.output = cpe.output
> +            except OSError as ose:
> +                raise general_error('bootstrap failed: %s in %s: %s' % \
> +                                        (' '.join(cmd), self.cwd, (str(ose))))
> +            except KeyboardInterrupt:
> +                pass
> +            except:
> +                raise
> +        except:
> +            self.result = sys.exc_info()
> +        self.end_time = datetime.datetime.now()
> +    def run(self):
> +        self.thread = threading.Thread(target = self.runner)
> +        self.thread.start()
> +    def is_alive(self):
> +        return self.thread and self.thread.is_alive()
> +    def reraise(self):
> +        if self.result is not None:
> +            raise self.result[0](self.result[1])
> +class autoreconf:
> +    def __init__(self, topdir, configure):
> +        self.topdir = topdir
> +        self.configure = configure
> +        self.cwd = os.path.dirname(self.configure)
> +        self.command = command(['autoreconf', '-i', '--no-recursive'], self.cwd)
> +        self.command.run()
> +        return self.command.is_alive()
> +    def post_process(self):
> +        if self.command is not None:
> +            self.command.reraise()
> +            if self.command.exit_code != 0:
> +                raise general_error('error: autoreconf: %s' % (' '.join(self.command.cmd)))
> +            makefile = os.path.join(self.cwd, 'Makefile.am')
> +            if os.path.exists(makefile):
> +                if _grep(makefile, 'stamp-h\.in'):
> +                    stamp_h = os.path.join(self.cwd, 'stamp-h.in')
> +                    try:
> +                        t = open(os.path.host(stamp_h), 'w')
> +                        t.write('timestamp')
> +                        t.close()
> +                        raise general_error('writing: %s' % (stamp_h))
> +def generate(topdir, jobs):
> +    if type(jobs) is str:
> +        jobs = int(jobs)
> +    start_time = datetime.datetime.now()
> +    confs = _collect(topdir, 'configure.ac')
> +    next = 0
> +    autoreconfs = []
> +    while next < len(confs) or len(autoreconfs) > 0:
> +        if next < len(confs) and len(autoreconfs) < jobs:
> +            print('%3d/%3d: autoreconf: %s' % \
> +                  (next + 1, len(confs), confs[next][len(topdir) + 1:]))
> +            autoreconfs += [autoreconf(topdir, confs[next])]
> +            next += 1
> +        else:
> +            for ac in autoreconfs:
> +                if not ac.is_alive():
> +                    ac.post_process()
> +                    autoreconfs.remove(ac)
> +                    del ac
> +            if len(autoreconfs) >= jobs:
> +                time.sleep(1)
> +    end_time = datetime.datetime.now()
> +    print('Bootstrap time: %s' % (str(end_time - start_time)))
> +def run(args):
> +    try:
> +        # On Windows MSYS2 prepends a path to itself to the environment
> +        # path. This means the RTEMS specific automake is not found and which
> +        # breaks the bootstrap. We need to remove the prepended path. Also
> +        # remove any ACLOCAL paths from the environment.
> +            cspath = os.environ['PATH'].split(os.pathsep)
> +            if 'msys' in cspath[0] and cspath[0].endswith('bin'):
> +                os.environ['PATH'] = os.pathsep.join(cspath[1:])
> +            if 'ACLOCAL_PATH' in os.environ:
> +                # The clear fails on a current MSYS2 python (Feb 2016). Delete
> +                # the entry if the clear fails.
> +                try:
> +                    os.environ['ACLOCAL_PATH'].clear()
> +                except:
> +                    del os.environ['ACLOCAL_PATH']
> +        argsp = argparse.ArgumentParser(prog = 'rtems-bootstrap',
> +                                        description = "Bootstrap in parallel")
> +        argsp.add_argument('-j', '--jobs',
> +                           help = 'number of jobs to run (default: %(default)s).',
> +                           type = int, default = multiprocessing.cpu_count())
> +        argsp.add_argument('-r', '--rtems',
> +                           type = str, default = os.getcwd(),
> +                           help = 'path to the rtems kernel source (default: %(default)s).')
> +        argopts = argsp.parse_args(args[1:])
> +        print('RTEMS Bootstrap, %s' % (version))
> +        if not os.path.exists(argopts.rtems):
> +            raise general_error('path does not exist: %s' % (argopts.rtems))
> +        if not os.path.isdir(argopts.rtems):
> +            raise general_error('path not a directory: %s' % (argopts.rtems))
> +        generate(argopts.rtems, argopts.jobs)
> +    except general_error as gerr:
> +        print(gerr)
> +        print('Bootstrap FAILED', file = sys.stderr)
> +        sys.exit(1)
> +        log.notice('abort: user terminated')
> +        sys.exit(1)
> +    sys.exit(0)
> +if __name__ == "__main__":
> +    run(sys.argv)
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
