rtems-addr2line not working on ARM?
Fri Sep 6 06:20:59 UTC 2019
Hello,
I tried the rtems-addr2line on ARM and SPARC. On SPARC it seems to work
fine, however, on ARM I get this:
rtems-addr2line -e
build/arm-rtems5-xilinx_zynq_a9_qemu-everything/media01.exe 0x0000135a
/home/EB/sebastian_h/git-rtems-5/c/src/lib/libbsp/arm/xilinx-zynq/../../../../../../bsps/arm/shared/irq/irq-gic.c:264
addr2line -e build/arm-rtems5-xilinx_zynq_a9_qemu-everything/media01.exe
0000135a
/scratch/git-rtems-libbsd/build/arm-rtems5-xilinx_zynq_a9_qemu-everything/../../testsuite/include/rtems/bsd/test/default-network-init.h:179
The GNU tool is right. It is also considerably faster. The mapping to
the function (-f option) get both tools right.
I don't understand the logic here:
     bool
     file::get_source (const unsigned int addr,
                       std::string&       source_file,
                       int&               source_line)
       address match;
       for (auto& cu : cus)
         address line;
         r = cu.get_source (addr, line);
         if (r)
<-- Why is there a "match = line" in both cases?
           if (match.valid () &&
               (match.is_an_end_sequence () || !!line.is_an_end_sequence
             match = line;
           else
             match = line;
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
