rtems-addr2line not working on ARM?
Sebastian Huber
Mon Sep 9 05:31:47 UTC 2019
On 07/09/2019 16:25, Sebastian Huber wrote:
> ----- Am 6. Sep 2019 um 18:06 schrieb Sebastian Huber sebastian.huber at embedded-brains.de:
>> ----- Am 6. Sep 2019 um 11:09 schrieb Sebastian Huber
>>> On 06/09/2019 09:26, Sebastian Huber wrote:
>>>> On 06/09/2019 09:01, Chris Johns wrote:
>>>>> On 6/9/19 4:20 pm, Sebastian Huber wrote:
>>>>>> Hello,
>>>>>> I tried the rtems-addr2line on ARM and SPARC. On SPARC it seems to
>>>>>> work fine,
>>>>>> however, on ARM I get this:
>>>>>> rtems-addr2line -e
>>>>>> build/arm-rtems5-xilinx_zynq_a9_qemu-everything/media01.exe
>>>>>> 0x0000135a
>>>>>> /home/EB/sebastian_h/git-rtems-5/c/src/lib/libbsp/arm/xilinx-zynq/../../../../../../bsps/arm/shared/irq/irq-gic.c:264
>>>>>> addr2line -e
>>>>>> build/arm-rtems5-xilinx_zynq_a9_qemu-everything/media01.exe 0000135a
>>>>>> /scratch/git-rtems-libbsd/build/arm-rtems5-xilinx_zynq_a9_qemu-everything/../../testsuite/include/rtems/bsd/test/default-network-init.h:179
>>>>>> The GNU tool is right. It is also considerably faster.
>>>>> I would hope it is faster and exact. It has had many years of work on it,
>>>>> written in C and not a means to test a C++ framework so we can grow an
>>>>> ecosystem. I have stated its purpose before. I am perplexed by the
>>>>> intent of
>>>>> this statement.
>>>>> If you want to compare performance I suggest you try the elftools one?
>>>>> There is
>>>>> one. It is not built because GNU provides one and good one.
>>>>> Also be-careful as the exec call is not as fast as Linux on all the
>>>>> hosts we
>>>>> support.
>>>> That the GNU tool is faster was just an observation.
>>>> Do we have a working library solution to get from an address to the
>>>> source line/function? I don't have time to debug the DWARF support code
>>>> at the moment.
>>>> I have a working solution using "addr2line" and rld::process::execute().
>>> Thanks for the hint to the elftoolchain:
>>> https://github.com/elftoolchain/elftoolchain/blob/trunk/addr2line/addr2line.c
>>> To me it looks pretty complicated. It should be possible to refactor
>>> this code to use it as a library, e.g. call translate() for each address
>>> you need the source information.
>>> I tried to debug the rld get_source() problem for more than two hours
>>> and the elftoolchain code looks similar. I am not sure what to do.
>> Another option is to use the LLVM infrastructure:
>> https://github.com/llvm-mirror/llvm/blob/master/tools/llvm-symbolizer/llvm-symbolizer.cpp
>> From a first glance, this looks like the way to go.
> Attached is a patch which uses the LLVM library to get an addr2line functionality. The code to resolve an address is very easy (item.data is the address):
> auto res_or_err = symbolizer_.symbolizeCode(elf_file_, item.data);
> if (res_or_err) {
> auto info = res_or_err.get();
> std::string fn = info.FunctionName;
> std::string str;
> if (fn != "<invalid>") {
> str += fn;
> str += " at ";
> str += llvm::sys::path::filename(info.FileName);
> str += ":";
> str += std::to_string(info.Line);
> LLVM has also support for command line arguments, file handling, etc.
The LLVM solution is also the fastest so far:
time ../build/trace/rtems-record-lttng -e media01.exe records.bin
real 0m0.425s
user 0m0.293s
sys 0m0.132s
addr2line based solution on Linux:
real 0m11.944s
user 0m5.334s
sys 0m6.593s
LLVM has also an API to access the DWARF debug information:
https://github.com/llvm-mirror/llvm/blob/master/tools/llvm-dwarfdump/llvm-dwarfdump.cpp
llvm-dwarfdump media.exe | grep '\<_Workspace_Allocate\>' -B 10 -A 40
0x0163bea5: DW_TAG_subprogram
DW_AT_external (true)
DW_AT_name ("_Workspace_Allocate")
DW_AT_decl_file ("wkspace.c")
DW_AT_decl_line (232)
DW_AT_prototyped (true)
DW_AT_type (0x016388fd "*")
DW_AT_low_pc (0x0000000000746092)
DW_AT_high_pc (0x00000000007460b4)
DW_AT_frame_base (DW_OP_call_frame_cfa)
DW_AT_unknown_2116 (true)
DW_AT_sibling (0x0163bedb)
0x0163bebe: DW_TAG_formal_parameter
DW_AT_name ("size")
DW_AT_decl_line (233)
DW_AT_type (0x01638817 "size_t")
DW_AT_location (DW_OP_fbreg -20)
This could be used to generate wrapper functions and generic record
function entry/exit consumers.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
