[RTEMS][PATCH v2 0/2] riscv: add freedom E310 Arty A7
Pragnesh Patel
pragnesh.patel at sifive.com
Wed Sep 11 13:07:10 UTC 2019
Fredom E310 Arty has a support for FDT but right now, u-boot (or any
bootloader) will not copy FDT address into CPU register (a1 for RISCV)
instead we have given FDT address manually as shown below:
bsps/riscv/shared/start/start.S
#ifdef BSP_START_COPY_FDT_FROM_U_BOOT
+ LADDR a1, frdme310arty_dtb
mv a0, a1
call bsp_fdt_copy
#endif
bsps/riscv/riscv/dts/frdme310arty_dtb_array.c
unsigned char frdme310arty_dtb[] = {
0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x38,
0x00, 0x00, 0x0a, 0x74, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
Can you suggest me a better way of doing this?
- Pragnesh
On Wed, Sep 11, 2019 at 2:18 PM Sebastian Huber
> On 11/09/2019 10:43, Pragnesh Patel wrote:
> > Ok understood.
> > If i will add Freedom E310 related code in bsp/riscv/riscv directory
> > then there are some code changes related to "console, btimer and other
> > minor things" so can i add this changes under new #define let's say
> > #define RISCV_ENABLE_FRDME310_SUPPORT ?
> Please don't add a new btimer driver. This is a legacy driver. For this
> BSP we can switch to the btimer-cpucounter.c variant.
> > I am planning to add this #define in configure.ac through
> > RTEMS_BSPOPTS_SET([RISCV_ENABLE_FRDME310_SUPPORT],[*],[1]), By default
> > it is disabled.
> > what's your suggestion on this?
> Yes, this sounds good. If there are to many places with this define,
> then we have to think again how to proceed.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
