Hi, Chris, It’s great to hear about rtems has made some progress on LLVM. I’m quite new to rtems, so I have questions about the rtems-llvm packages 1. Can I use rtems-llvm clang compiler build application c code? 2. Does rtems code and newlib still need use arm gcc toolchain? mko_io
