LLVM on openSUSE 15.1
Tue Sep 17 05:32:43 UTC 2019
Hello,
I didn't get far:
config.status: creating t/wrap/automake-1.12
+ make -j 12 all
   GEN      automake
   GEN      aclocal
   GEN      t/ax/shell-no-trail-bslash
   GEN      doc/aclocal.1
   GEN      doc/automake.1
   GEN      runtest
   GEN      t/ax/test-defs.sh
   GEN      lib/Automake/Config.pm
   GEN      doc/aclocal-1.12.1
   GEN      doc/automake-1.12.1
help2man: can't get `--help' info from automake-1.12
Try `--no-discard-stderr' if option outputs to stderr
make: *** [Makefile:4114: doc/automake-1.12.1] Error 255
I removed the swig build and ended up here:
CMake Error: The following variables are used in this project, but they
are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the
CMake files:
/scratch/git-rtems-source-builder/rtems/build/rtems-llvm-8.0.1-x86_64-linux-gnu-1/llvm-8.0.1/tools/lldb/scripts/Python/modules/readline/libedit_INCLUDE_DIRS
    used as include directory in directory
/scratch/git-rtems-source-builder/rtems/build/rtems-llvm-8.0.1-x86_64-linux-gnu-1/llvm-8.0.1/tools/lldb/source/Core/libedit_INCLUDE_DIRS
/scratch/git-rtems-source-builder/rtems/build/rtems-llvm-8.0.1-x86_64-linux-gnu-1/llvm-8.0.1/tools/lldb/source/Host/libedit_INCLUDE_DIRS
/scratch/git-rtems-source-builder/rtems/build/rtems-llvm-8.0.1-x86_64-linux-gnu-1/llvm-8.0.1/tools/lldb/source/Interpreter/libedit_INCLUDE_DIRS
libedit_LIBRARIES (ADVANCED)
     linked by target "readline" in directory
I guess I will stick to the openSUSE package for LLVM.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
