rtems-tester initial port getting "'NoneType' object is not iterable"
dufault at hda.com
dufault at hda.com
Fri Sep 20 19:56:26 UTC 2019
One thing I should have said is that “rtems" and "rtems-tester" are the master branches, "rtems-tester" is updated as of yesterday, and “rtems” is recent.
> On Sep 20, 2019, at 15:46 , Peter Dufault <dufault at hda.com> wrote:
> I’m bringing up the rtems-tester for the PowerPC “beatnik” bsp. I’m impressed with how easy it is to implement (well done, Chris). But after doing all the easy work, and just as I thought my initial run of the “samples" was about to exit successfully, the script faulted and gave me the error "TypeError: 'NoneType' object is not iterable”. I’ve pasted the output of my run below.
> There’s no useful information in the output of the log file. It ends with the summary of what passed, failed, and the time it took, the same as you see below in the pasted output.
> I looked at the called-out line in the python code. It’s trying to generate reports, I think. Maybe I missed a required configuration step to specify a format that isn’t detected until this happens?
> - What have I neglected to send?
> - Anybody seen this? I couldn’t find it via searches.
> This is the console output from when I ran the test. *Note that “ltimer.exe” is not a real RTEMS sample test, and that’s why it shows up as an invalid result.*
> [dufault at gen6 lou_files]$ ./my_beatnik.sh
> RTEMS Testing - Tester, 5 (12bd8f77bad4)
> [ 1/14] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | powerpc/beatnik: base_sp.exe
> [ 2/14] p:1 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | powerpc/beatnik: capture.exe
> [ 3/14] p:1 f:0 u:1 e:0 I:0 B:0 t:0 i:0 W:0 | powerpc/beatnik: cdtest.exe
> [ 4/14] p:2 f:0 u:1 e:0 I:0 B:0 t:0 i:0 W:0 | powerpc/beatnik: cxx_iostream.exe
> [ 5/14] p:3 f:0 u:1 e:0 I:0 B:0 t:0 i:0 W:0 | powerpc/beatnik: fileio.exe
> [ 6/14] p:3 f:0 u:2 e:0 I:0 B:0 t:0 i:0 W:0 | powerpc/beatnik: hello.exe
> [ 7/14] p:4 f:0 u:2 e:0 I:0 B:0 t:0 i:0 W:0 | powerpc/beatnik: loopback.exe
> [ 8/14] p:5 f:0 u:2 e:0 I:0 B:0 t:0 i:0 W:0 | powerpc/beatnik: ltimer.exe
> [ 9/14] p:5 f:0 u:2 e:0 I:0 B:0 t:0 i:1 W:0 | powerpc/beatnik: minimum.exe
> [10/14] p:6 f:0 u:2 e:0 I:0 B:0 t:0 i:1 W:0 | powerpc/beatnik: nsecs.exe
> [11/14] p:7 f:0 u:2 e:0 I:0 B:0 t:0 i:1 W:0 | powerpc/beatnik: paranoia.exe
> [12/14] p:8 f:0 u:2 e:0 I:0 B:0 t:0 i:1 W:0 | powerpc/beatnik: pppd.exe
> [13/14] p:9 f:0 u:2 e:0 I:0 B:0 t:0 i:1 W:0 | powerpc/beatnik: ticker.exe
> [14/14] p:10 f:0 u:2 e:0 I:0 B:0 t:0 i:1 W:0 | powerpc/beatnik: unlimited.exe
> Passed: 11
> Failed: 0
> User Input: 2
> Expected Fail: 0
> Indeterminate: 0
> Benchmark: 0
> Timeout: 0
> Invalid: 1
> Wrong Version: 0
> Wrong Build: 0
> Wrong Tools: 0
> Total: 14
> Average test time: 0:00:40.583694
> Testing time : 0:09:28.171711
> Traceback (most recent call last):
> File "../rtems-tools/tester/rt/cmd-test.py", line 42, in <module>
> test.run(sys.argv[1:], command_path = base)
> File "/home/dufault/development/rtems/rtems-tools/tester/rt/test.py", line 455, in run
> for report_format in report_formats:
> Peter
> Peter Dufault
> HD Associates, Inc. Software and System Engineering
> This email is delivered through the public internet using protocols subject to interception and tampering.
> devel mailing list
> devel at rtems.org
Peter
Peter Dufault
