Problem running sparc-rtems5-gdb
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sun Sep 22 04:59:06 UTC 2019
On Sun, Sep 22, 2019 at 10:01 AM Niteesh <gsnb.gn at gmail.com> wrote:
> I was following the quick-start guide from
> https://docs.rtems.org/branches/master/user/start/index.html
> I followed the exact steps but still couldn't get the hello world
> running. I face issues when running the GDB, when trying to set the
> target to simulator I get "undefined target cmd: sim",
> Is it an issue on my side or is something missing in the docs?
Hi Niteesh,
Usually, it is enough to post to any one of devel or users list.
Can you please post the exact command sequence that gave you the
error? You can copy the command output here if it's not long, or paste
it somewhere like a github gist and send the link here.
Best regards,
Vijay
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190922/1a25c4ab/attachment-0002.html>
