Suggestions about rtems-ld
jameszxj jameszxj at gmail.com
Sun Sep 22 05:01:19 UTC 2019
Hi,
   1. option -e (--entry)
       In most cases, entry point is useless when use dynamic load. Default entry point "rtems" makes user must provid a entry point or provid "rtems" entry point.
I think make default entry point to null is better, if user does not assign one. If it is acceptable, I'll submit a patch.
   2. unresolved symbols
       Dynamically loader code should have unresolved symbols most time, but rtems-ld throws an error when encounters a unresolved symbol.  Assign baseimage
can solve part of the problems. When unresolved symbols scatter at 2 or more files, just one baseimage is not enough.
       If just print a warning,  Maybe hundreds of warnings output, this still bothers the user. GNU ld does not print anything about it.
       Just print a warning or slient, I could't say which is better.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190922/3bdf287c/attachment-0002.html>
