Problem running sparc-rtems5-gdb
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Sep 22 08:13:46 UTC 2019
On Sun, Sep 22, 2019, 1:22 PM Niteesh <gsnb.gn at gmail.com> wrote:
> Sorry, for so many questions.
> But I was actually following the latest quick start guide, but it is
> lacking information on building and running applications, the last page on
> quick start section was about testing the BSP. That's why I had to refer to
> the old wiki section.
The doc has been updated recently and I don't know if someone is working on
it or not. I see a todo section there, which probably is for building and
running apps.
how could I patch this?
Everyone: Where to add the guide to build and run hello world in docs?
>> On Sun, Sep 22, 2019 at 1:01 PM Vijay Kumar Banerjee a<
> vijaykumar9597 at gmail.com> wrote:
>> On Sun, Sep 22, 2019 at 12:59 PM Niteesh <gsnb.gn at gmail.com> wrote:
>>> https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start#Running
>>> I actually changed the rtems version from 4.11 to 5 in the command,
>>> there was no documentation about the change in version 5.
>>> This wiki page is a bit outdated and marked as "To be removed". You
>> should
>> follow the latest docs quickstart guide:
>> https://docs.rtems.org/branches/master/user/start/index.html
>>> On Sun, Sep 22, 2019 at 12:30 PM Vijay Kumar Banerjee <
>>>> Hello,
>>>> I just checked that the built-in sis in gdb has been disabled in this
>>>> commit:
>>>> https://git.rtems.org/rtems-source-builder/commit/?id=abc540105d10ddc9cad7de3c7ac0a9aa209ac828
>>>> Niteesh: This means that the command you should use is
>>>> `sparc-rtems5-sis`.
>>>> Can you please post the link to the exact page where the
>>>> `sparc-rtems5-gdb`
>>>> steps are mentioned with `tar sim`? I think this would need to be
>>>> updated and
>>>> you can propose a patch for this.
>>>> Best regards,
>>>> Vijay
>>>> On Sun, Sep 22, 2019 at 11:04 AM Vijay Kumar Banerjee <
>>>>> ( Please use the reply to all option to keep the conversation on the
>>>>> list )
>>>>> On Sun, Sep 22, 2019 at 10:50 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>>>>> bsp: erc32
>>>>>> arch: sparc
>>>>>> Odd. It is expected to work in erc32 if your build is right. I don't
>>>>> have a
>>>>> recent sparc build so I can't verify right now.
>>>>> Let's wait for other people to join and help with the issue. :)
>>>>>> On Sun, Sep 22, 2019 at 10:49 AM Vijay Kumar Banerjee <
>>>>>>> On Sun, Sep 22, 2019 at 10:35 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>>>>>>> The problem actually occurred when I was trying to run the
>>>>>>>> hello.exe with gdb.
>>>>>>>> 1: *sparc-rtems5-gdb hello.exe*
>>>>>>>> and inside gdb to set the target as simulator.
>>>>>>>> 2: *tar sim*
>>>>>>>> This is the expected sequence, what BSP are you using?
>>>>>>>> (gdb) tar sim
>>>>>>>> Undefined target command: "sim". Try "help target".
>>>>>>>> While going through some stackoverflow posts I found that to target
>>>>>>>> simulators --enable-sim has to given while building gdb, Is this the
>>>>>>>> problem or am I missing something?
>>>>>>>> On Sun, Sep 22, 2019 at 10:29 AM Vijay Kumar Banerjee <
>>>>>>>>> On Sun, Sep 22, 2019 at 10:01 AM Niteesh <gsnb.gn at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> I was following the quick-start guide from
>>>>>>>>>> I followed the exact steps but still couldn't get the hello world
>>>>>>>>>> running. I face issues when running the GDB, when trying to set
>>>>>>>>>> the
>>>>>>>>>> target to simulator I get "undefined target cmd: sim",
>>>>>>>>>> Is it an issue on my side or is something missing in the docs?
>>>>>>>>> Hi Niteesh,
>>>>>>>>> Usually, it is enough to post to any one of devel or users list.
>>>>>>>>> Can you please post the exact command sequence that gave you the
>>>>>>>>> error? You can copy the command output here if it's not long, or
>>>>>>>>> paste
>>>>>>>>> it somewhere like a github gist and send the link here.
>>>>>>>>> Best regards,
>>>>>>>>> Vijay
>>>>>>>>>> _______________________________________________
>>>>>>>>>> devel mailing list
>>>>>>>>>> devel at rtems.org
>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190922/5c2f57c2/attachment-0002.html>
