rtems tester: Why does rtems_test_assert() just exit?
dufault at hda.com dufault at hda.com
Mon Sep 23 11:50:12 UTC 2019
> On Sep 22, 2019, at 18:45 , Chris Johns <chrisj at rtems.org> wrote:
> On 23/9/19 12:33 am, dufault at hda.com wrote:
>>> On Sep 22, 2019, at 07:12 , <dufault at hda.com> <dufault at hda.com> wrote:
>>>> On Sep 21, 2019, at 17:29 , dufault at hda.com wrote:
>>>>> On Sep 21, 2019, at 17:04 , Chris Johns <chrisj at rtems.org> wrote:
>>>>> The tester is designed to avoid cycling power. A clean working target should
>>>>> only need a single power on at the start and a single power off at the end.
>>>>> Repeated power cycling can stress power supplies and targets, some switch modes
>>>>> do not like it. Some targets have hardware reset issues and may need a power
>>>>> cycle and I have seen uboot get wedged. The power cycle logic is for those
>>>>> cases. I would not expect this being needed on each boot. Also it is a reset
>>>>> which can be a power cycle or a wired reset signal however some SOCs these days
>>>>> have separate power on reset (POR) logic and a reset signal logic.
>>>>> Chris
>>>> You are bringing up most of my concerns in your response, I’ll go over your response properly tomorrow AM when I’ll have free time.  Thanks.
>>> I think if I change "rtems_test_assert()" to invoke "exit(RTEMS_FATAL_SOURCE_ASSERT)" instead of "exit(0)" and then use the following for the reset expression it will do what I would like.  I'm sure there is a better way to do that regular expression but I'll use this for a test.
>>> target_reset_regex = .* RTEMS_FATAL_SOURCE_BDBUF, .*|.* RTEMS_FATAL_SOURCE_APPLICATION, .*|.* RTEMS_FATAL_SOURCE_BSP, .*|.* RTEMS_FATAL_SOURCE_ASSERT, .*|.* RTEMS_FATAL_SOURCE_STACK_CHECKER, .*|.* RTEMS_FATAL_SOURCE_EXCEPTION, .*|.* RTEMS_FATAL_SOURCE_SMP, .*|.* RTEMS_FATAL_SOURCE_PANIC, .*|.* RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE, .*
> The tester knows the test has finished with '*** END OF TEST ' so it will end
> the test when this message is seen. If your host is fast or the console is
> buffered the test will finish and be looking for the test begin message and if a
> reset trigger is seen in the output from the end of the previous test the board
> will reset as part of the start of the next test.
> In theory a good quality target should not need any reset triggers however it
> will need a start trigger to catch a test failing without any output and restarting.
>> This doesn't work as I'd hoped.  There is pending input to the tester from the tested device's serial port console.  If the tester matches the reset condition *after* the first reset but *before* the board restarts it will issue the reset again.
>> In the case of "unlimited.exe" the following is what happened.  I watched the tester power cycle the board off and on about 15 times before it advanced to the next test.
>> After issuing the reset command should the tester advance through the console output without taking action until it sees the start expression?
>> ]  TEST3 : signal task 0a01034e to delete, task 844 ending.
>> =>  target reset condition detected
>> =>  target reset: ./power-ctl 1 off-on
>> ]  TEST3 : signal task 0a01034f to delete, fatal source: RTEMS_FATAL_SOURCE_EXCEPTION, error code: 9018872
>> ] exception vector 7 (0x7)
>> ]   next PC or address of fault = 0x00890038
>> ]   executing thread ID = 0x0a01034f, name = ai45
>> ] Stack Trace:
>> ]   IP: 0x00890038, LR: 0x0089003a
>> ] fatal source: RTEMS_FATAL_SOURCE_EXCEPTION, error code: 9018088
>> ] exception vector 3 (0x3)
> Is this from the power being turned off? If it is this would cause a loop if in
> the reset trigger.
No, whatever error happened in "unlmited.exe" generated a cascade of errors and so they are all in the console output for the tester to read.  The tester reads through them sequentially and keeps cycling power off and on.
I did put in the change for the tester to cycle to a start expression after it issues a reset without issuing multiple resets.  That almost did what I wanted in that it cycled to the start without any more resets.  The tester did not end the test, though, so it issued a second reset when the board requested a TFTP transfer request.
I'll think about this a little more, I don't think these are really RESET regular expressions but an "outside of the current tester's framework" failure regular expression.
These RTEMS_FATAL_FUBAR errors mean:
- The test has failed, and the test is going to reset the board momentarily.  There's no need for the tester to do a reset, the tester can fail this test and advance to the next test and download the next test at the next TFTP transfer request.
- The test has failed catastrophically, and we're now going to get a possibly infinite cascade of these errors.  Rather than wait for a three minute timeout of cascading errors it would be nice to count to a certain number, reset, fail the test and continue to the next one.
My goal is also to approach the ideal of an initial power-up / final power-down power sequence.  I have a few thoughts about the user input tests as well but I'll think more about it first.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
