[PATCH] Fix exception when no output format is specified
Chris Johns
chrisj at rtems.org
Mon Sep 23 22:42:57 UTC 2019
Pushed. Thanks.
It may pay to update the RSB to pick this change up.
On 23/9/19 11:33 pm, Kinsey Moore wrote:
> The JSON log generation patch introduced a bug when the report output
> generation was not configured due to attempting to iterate over 'None'.
> tester/rt/test.py | 2 ++
> 1 file changed, 2 insertions(+)
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index d5c7c66..d258b11 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -345,6 +345,8 @@ def run(args, command_path = None):
> raise error.general('invalid RTEMS report formats option')
> report_formats = report_formats[1].split(',')
> check_report_formats(report_formats, report_location)
> + else:
> + report_formats = []
> log.notice('RTEMS Testing - Tester, %s' % (version.string()))
> if opts.find_arg('--list-bsps'):
> bsps.list(opts)
