[rtems-libbsd commit] Add pselect()
Joel Sherrill
joel at rtems.org
Tue Sep 24 13:34:19 UTC 2019
Hi
Before I update the compliance tracking to add pselect(), have any other
POSIX methods been added recently which I have missed?
Thanks.
--joel
On Mon, Sep 23, 2019 at 7:38 AM Sebastian Huber <sebh at rtems.org> wrote:
> Module: rtems-libbsd
> Branch: master
> Commit: cff1625f2787e08f33e67f949c0722c0aa05f618
> Changeset: http://git.rtems.org/rtems-libbsd/commit/?id=cff1625f2787e08f33e67f949c0722c0aa05f618
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Mon Sep 23 14:27:32 2019 +0200
> Add pselect()
> freebsd/sys/kern/sys_generic.c | 37 ++++++++++++++++
> testsuite/selectpollkqueue01/test_main.c | 62 +++++++++++++++++++++++++-
> testsuite/syscalls01/test_main.c | 76 ++++++++++++++++++++++++++++++++
> 3 files changed, 174 insertions(+), 1 deletion(-)
> diff --git a/freebsd/sys/kern/sys_generic.c b/freebsd/sys/kern/sys_generic.c
> index 24da393..cc208d6 100644
> --- a/freebsd/sys/kern/sys_generic.c
> +++ b/freebsd/sys/kern/sys_generic.c
> @@ -1179,6 +1179,43 @@ select(int nfds, fd_set *readfds, fd_set *writefds, fd_set *errorfds,
> rtems_set_errno_and_return_minus_one(error);
> +int
> +pselect(int nfds, fd_set *readfds, fd_set *writefds, fd_set *errorfds,
> + const struct timespec *timeout, const sigset_t *set)
> + struct thread *td;
> + int error;
> + if (set != NULL) {
> + rtems_set_errno_and_return_minus_one(ENOSYS);
> + td = rtems_bsd_get_curthread_or_null();
> + if (td != NULL) {
> + struct timeval tv;
> + struct timeval *tvp;
> + if (timeout != NULL) {
> + TIMESPEC_TO_TIMEVAL(&tv, timeout);
> + tvp = &tv;
> + } else {
> + tvp = NULL;
> + error = kern_select(td, nfds, readfds, writefds, errorfds,
> + tvp, NFDBITS);
> + } else {
> + error = ENOMEM;
> + if (error == 0) {
> + return td->td_retval[0];
> + } else {
> + rtems_set_errno_and_return_minus_one(error);
> #endif /* __rtems__ */
> diff --git a/testsuite/selectpollkqueue01/test_main.c b/testsuite/selectpollkqueue01/test_main.c
> index fc05643..244f5b5 100755
> --- a/testsuite/selectpollkqueue01/test_main.c
> +++ b/testsuite/selectpollkqueue01/test_main.c
> @@ -1,5 +1,5 @@
> - * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
> + * Copyright (c) 2013, 2019 embedded brains GmbH. All rights reserved.
> * embedded brains GmbH
> * Dornierstr. 4
> @@ -522,6 +522,63 @@ test_select_close(test_context *ctx)
> static void
> +test_pselect_sigmask(void)
> + int rv;
> + sigset_t set;
> + puts("test pselect sigmask");
> + sigemptyset(&set);
> + errno = 0;
> + rv = pselect(0, NULL, NULL, NULL, NULL, &set);
> + assert(rv == -1);
> + assert(errno == ENOSYS);
> +static void
> +test_pselect_timeout(test_context *ctx)
> + struct timespec timeout = {
> + .tv_sec = 0,
> + .tv_nsec = 100000000
> + int fd = ctx->lfd;
> + int nfds = fd + 1;
> + struct fd_set set;
> + int rv;
> + int i;
> + puts("test pselect timeout");
> + set_non_blocking(ctx->lfd, 0);
> + FD_ZERO(&set);
> + FD_SET(fd, &set);
> + rv = pselect(nfds, &set, NULL, NULL, &timeout, NULL);
> + assert(rv == 0);
> + for (i = 0; i < nfds; ++i) {
> + assert(!FD_ISSET(i, &set));
> + rv = pselect(nfds, NULL, &set, NULL, &timeout, NULL);
> + assert(rv == 0);
> + rv = pselect(nfds, NULL, NULL, &set, &timeout, NULL);
> + assert(rv == 0);
> +static void
> test_poll_timeout(test_context *ctx)
> static const short events[] = {
> @@ -1199,6 +1256,9 @@ test_main(void)
> test_select_write(ctx);
> test_select_close(ctx);
> + test_pselect_sigmask();
> + test_pselect_timeout(ctx);
> test_poll_timeout(ctx);
> test_poll_connect(ctx);
> test_poll_read(ctx);
> diff --git a/testsuite/syscalls01/test_main.c b/testsuite/syscalls01/test_main.c
> index b95a6c2..3254ba5 100644
> --- a/testsuite/syscalls01/test_main.c
> +++ b/testsuite/syscalls01/test_main.c
> @@ -1329,6 +1329,81 @@ test_socket_select(void)
> static void
> +no_mem_socket_pselect(int fd)
> + int nfds;
> + int rv;
> + FD_ZERO(&set);
> + FD_SET(fd, &set);
> + nfds = fd + 1;
> + errno = 0;
> + rv = pselect(nfds, &set, NULL, NULL, NULL, NULL);
> + assert(rv == -1);
> + assert(errno == ENOMEM);
> +static void
> +test_socket_pselect(void)
> + rtems_resource_snapshot snapshot;
> + int nfds;
> + int sd;
> + int rv;
> + puts("test socket pselect");
> + sd = socket(PF_INET, SOCK_DGRAM, 0);
> + assert(sd >= 0);
> + rv = close(sd);
> + assert(rv == 0);
> + FD_ZERO(&set);
> + FD_SET(sd, &set);
> + nfds = sd + 1;
> + errno = 0;
> + assert(rv == -1);
> + assert(errno == EBADF);
> + epoch_cleanup();
> + rtems_resource_snapshot_take(&snapshot);
> + assert(sd >= 0);
> + do_no_mem_test(no_mem_socket_pselect, sd);
> + FD_ZERO(&set);
> + nfds = -1;
> + errno = 0;
> + assert(rv == -1);
> + assert(errno == EINVAL);
> + rv = close(sd);
> + assert(rv == 0);
> + FD_ZERO(&set);
> + FD_SET(sd, &set);
> + nfds = sd + 1;
> + errno = 0;
> + assert(rv == -1);
> + epoch_cleanup();
> + assert(rtems_resource_snapshot_check(&snapshot));
> +static void
> no_mem_socket_poll(int fd)
> struct pollfd pfd;
> @@ -1662,6 +1737,7 @@ test_main(void)
> test_socket_send_and_sendto_and_sendmsg();
> test_socket_recv_and_recvfrom_and_recvmsg();
> test_socket_select();
> + test_socket_pselect();
> test_socket_poll();
> test_socket_pair();
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
