[PATCH] implementation of smp test smpmrsp02
Ricardo Gomes (1161078)
1161078 at isep.ipp.pt
Tue Sep 24 17:08:34 UTC 2019
testsuites/smptests/Makefile.am | 16 ++
testsuites/smptests/configure.ac | 2 +
testsuites/smptests/smpmrsp02/init.c | 231 ++++++++++++++++++++
testsuites/smptests/smpmrsp02/smpmrsp02.doc | 15 ++
4 files changed, 264 insertions(+)
create mode 100755 testsuites/smptests/smpmrsp02/init.c
create mode 100644 testsuites/smptests/smpmrsp02/smpmrsp02.doc
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 38cc87e3c5..edb6478b8f 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -314,6 +314,18 @@ smpmrsp01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_smpmrsp01) \
endif
endif
+if HAS_SMP
+if TEST_smpmrsp02
+smp_tests += smpmrsp02
+smp_screens += smpmrsp02/smpmrsp02.scn
+smp_docs += smpmrsp02/smpmrsp02.doc
+smpmrsp02_SOURCES = smpmrsp02/init.c
+smpmrsp02_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_smpmrsp02) \
+ $(support_includes)
+endif
+endif
if HAS_SMP
if TEST_smpmulticast01
smp_tests += smpmulticast01
@@ -670,4 +682,8 @@ smpwakeafter01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_smpwakeafter01) \
endif
endif
noinst_PROGRAMS = $(smp_tests)
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 83b5b9fe41..6336b4e481 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -60,6 +60,7 @@ RTEMS_TEST_CHECK([smplock01])
RTEMS_TEST_CHECK([smpmigration01])
RTEMS_TEST_CHECK([smpmigration02])
RTEMS_TEST_CHECK([smpmrsp01])
+RTEMS_TEST_CHECK([smpmrsp02])
RTEMS_TEST_CHECK([smpmulticast01])
RTEMS_TEST_CHECK([smpmutex01])
RTEMS_TEST_CHECK([smpmutex02])
@@ -93,5 +94,6 @@ RTEMS_TEST_CHECK([smpthreadpin01])
RTEMS_TEST_CHECK([smpunsupported01])
RTEMS_TEST_CHECK([smpwakeafter01])
AC_CONFIG_FILES([Makefile])
AC_OUTPUT
diff --git a/testsuites/smptests/smpmrsp02/init.c b/testsuites/smptests/smpmrsp02/init.c
new file mode 100755
index 0000000000..c097fde50b
--- /dev/null
+++ b/testsuites/smptests/smpmrsp02/init.c
@@ -0,0 +1,231 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 Ricardo Gomes
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/param.h>
+#include <stdio.h>
+#include <inttypes.h>
+#include <rtems.h>
+#include <rtems/libcsupport.h>
+#include <rtems/score/schedulersmpimpl.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SMPMRSP 2";
+#define CPU_COUNT 2
+typedef struct
+ rtems_id init_id;
+ rtems_id scheduler_ids[CPU_COUNT];
+ rtems_id mrsp_id;
+ rtems_id task_id;
+} test_context;
+static test_context test_instance;
+static void assert_priority(rtems_id task_id, rtems_task_priority priority)
+ rtems_status_code sc;
+ rtems_task_priority prio;
+ sc = rtems_task_set_priority(task_id, RTEMS_CURRENT_PRIORITY, &prio);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ rtems_test_assert(priority == prio);
+ * Verifying if it is possible to define a priority ceiling
+ * on each scheduler instance
+static void create_semaphore(test_context *ctx, rtems_id *id, rtems_task_priority prio)
+ uint32_t index;
+ sc = rtems_semaphore_create(
+ rtems_build_name('M', 'R', 'S', 'P'),
+ 1,
+ RTEMS_MULTIPROCESSOR_RESOURCE_SHARING | RTEMS_BINARY_SEMAPHORE,
+ prio,
+ id);
+ rtems_task_priority old_prio;
+ old_prio = 1;
+ sc = rtems_semaphore_set_priority(
+ *id,
+ ctx->scheduler_ids[1],
+ prio + 1,
+ &old_prio);
+ prio = 2;
+ for (index = 0; index < CPU_COUNT; index++)
+ rtems_task_priority pr = RTEMS_CURRENT_PRIORITY;
+ sc = rtems_semaphore_set_priority(*id, ctx->scheduler_ids[index], pr, &pr);
+ rtems_test_assert(prio == pr);
+ printf("CPU %d CEILING PRIORITY = %" PRIu32 "\n", index, pr);
+ prio++;
+static void test_prio_per_proc(test_context *ctx)
+ printf("\n--TESTING IF THERE IS ONE CEILING PER PROCESSOR--\n\n");
+ rtems_task_priority prio = 2;
+ create_semaphore(ctx, &ctx->mrsp_id, prio);
+ printf("\n-------------------------------------------------\n");
+* Verification of the priority changes
+* when a task tries to obtain a MrsP semaphore
+static void high_task_prio_obtain(rtems_task_argument arg)
+ test_context *ctx = &test_instance;
+ printf("TASK - before obtain the priority should be 6\n");
+ assert_priority(RTEMS_SELF, 6);
+ sc = rtems_semaphore_obtain(ctx->mrsp_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ printf("TASK - after obtain the priority should be 3\n");
+ assert_priority(RTEMS_SELF, 3);
+ sc = rtems_semaphore_release(ctx->mrsp_id);
+ printf("TASK - after release the priority should be 6\n");
+ rtems_task_exit();
+static void test_prio_raise(test_context *ctx)
+ printf("\n--TESTING IF THERE IS PRIORITY RAISE OBTAINING THE RESOURCE--\n");
+ rtems_status_code sc = rtems_task_create(
+ rtems_build_name('T', 'A', 'S', 'K'),
+ 6,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &ctx->task_id);
+ sc = rtems_task_set_scheduler(ctx->task_id, ctx->scheduler_ids[1], 6);
+ printf("\nINIT- obtains the resource \n\n");
+ sc = rtems_task_start(ctx->task_id, high_task_prio_obtain, 0);
+ sc = rtems_task_wake_after(2 * rtems_clock_get_ticks_per_second());
+ printf("TASK - trying to obtain on CPU 1, the priority should be 3\n");
+ assert_priority(ctx->task_id, 3);
+ printf("\nINIT- releases the resource \n\n");
+ sc = rtems_task_wake_after(5 * rtems_clock_get_ticks_per_second());
+static void Init(rtems_task_argument arg)
+ TEST_BEGIN();
+ uint32_t cpu_index;
+ ctx->init_id = rtems_task_self();
+ for (cpu_index = 0; cpu_index < CPU_COUNT; ++cpu_index)
+ sc = rtems_scheduler_ident(cpu_index, &ctx->scheduler_ids[cpu_index]);
+ sc = rtems_task_set_scheduler(RTEMS_SELF, ctx->scheduler_ids[0], 4);
+ test_prio_per_proc(ctx);
+ test_prio_raise(ctx);
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_SCHEDULER_SIMPLE_SMP
+#include <rtems/scheduler.h>
+RTEMS_SCHEDULER_SIMPLE_SMP(0);
+RTEMS_SCHEDULER_SIMPLE_SMP(1);
+#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
+ RTEMS_SCHEDULER_TABLE_SIMPLE_SMP(0, 0), \
+ RTEMS_SCHEDULER_TABLE_SIMPLE_SMP(1, 1)
+#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
+ RTEMS_SCHEDULER_ASSIGN(0, 0), \
+ RTEMS_SCHEDULER_ASSIGN(1, 1)
+#define CONFIGURE_INIT_TASK_NAME rtems_build_name('M', 'A', 'I', 'N')
+#define CONFIGURE_INIT_TASK_PRIORITY 4
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpmrsp02/smpmrsp02.doc b/testsuites/smptests/smpmrsp02/smpmrsp02.doc
new file mode 100644
index 0000000000..184f404643
--- /dev/null
+++ b/testsuites/smptests/smpmrsp02/smpmrsp02.doc
@@ -0,0 +1,15 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpmrsp02
+directives:
+ rtems_semaphore_create
+ rtems_semaphore_obtain
+ rtems_semaphore_release
+ rtems_semaphore_set_priority
+concepts:
++ verify if a MrsP semaphore may have a set of priority ceilings, one per scheduler instance.
++ Verify if, when a task tries or obtains a MrsP semaphore, its priority is immediatly raised to the priority ceiling defined to that semaphore, on its own scheduler instance.
2.17.1
