Problem running sparc-rtems5-gdb
Joel Sherrill
joel at rtems.org
Wed Sep 25 12:31:45 UTC 2019
On Wed, Sep 25, 2019, 7:10 AM Niteesh <gsnb.gn at gmail.com> wrote:
> I would love to. I will start working on it soon.
> On Tue, 24 Sep 2019, 11:01 pm Vijay Kumar Banerjee, <
> vijaykumar9597 at gmail.com> wrote:
>> On Tue, Sep 24, 2019 at 11:00 PM Vijay Kumar Banerjee <
>>> On Tue, Sep 24, 2019 at 8:42 PM Gedare Bloom <gedare at rtems.org> wrote:
>>>> On Sun, Sep 22, 2019 at 2:14 AM Vijay Kumar Banerjee
>>>> <vijaykumar9597 at gmail.com> wrote:
>>>> > On Sun, Sep 22, 2019, 1:22 PM Niteesh <gsnb.gn at gmail.com> wrote:
>>>> >> Sorry, for so many questions.
>>>> >> But I was actually following the latest quick start guide, but it is
>>>> lacking information on building and running applications, the last page on
>>>> quick start section was about testing the BSP. That's why I had to refer to
>>>> the old wiki section.
>>>> > The doc has been updated recently and I don't know if someone is
>>>> working on it or not. I see a todo section there, which probably is for
>>>> building and running apps.
>>>> >> how could I patch this?
>>>> > Everyone: Where to add the guide to build and run hello world in docs?
>>>> The User Manual Ch. 2 Quick Start is the right place.
>>> Thanks Gedare!
>>> Niteesh: Would you like to add the instructions to the docs? you will
>>> basically have
>>> to add the steps you followed to get your hello world running. :)
Yes please. When the special bsp for the sparc instruction simulator went
away, that caused all these same docs and getting starteds to have to
change. Please help us update again.
Now they need both running and debugging instructions.
Hopefully the Users Guide can be the canonical source and everything else
reference that. The GSoC Hello World also needs attention
>>> to write the documentation:
>>> 1. git clone git://git.rtems.org/rtems-docs.git
>>> 2. follow the README.txt to build the docs
>>> 3. add a hello-world.rst under rtems-docs/user/start and write the
>>> content.
>>> Please don't hesitate to ask any question that you might have.
>>> Best regards,
>>> Vijay.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190925/e96cf57b/attachment-0002.html>
