Help on Newlib x86_64 fenv.h
Wed Sep 25 22:12:28 UTC 2019
Hi
Attached is the script from Jeff Johnson I have been using to
bootstrap newlib. It needs localizing for the paths.
I posted patches to add i386 and x86_64 fenv.h support. They are
attached. The i386 builds and runs fine. I can't get newlib
bootstrapped where it will descend into the directory. The files
configure.host and libm/machine/configure.in have architecture
specific magic and I got that.
You must use automake 1.11.6 and automake 2.68 to bootstrap.
Help is appreciated so I can move forward to fenv.h support for other
architectures and i386 long double math.
I expect this is something simple I am missing but I have stuck here
over a week.
Thanks.
--joel
Type: text/x-sh
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190925/fed75b5f/attachment-0002.bin>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190925/fed75b5f/attachment-0004.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190925/fed75b5f/attachment-0005.obj>
