[PATCH] bsps/beagle: update i2c section
Christian Mauderer
list at c-mauderer.de
Fri Sep 27 08:21:42 UTC 2019
Hello Vijay,
thanks for the update. I pushed it.
Best regards
Christian
On 24/09/2019 20:44, Vijay Kumar Banerjee wrote:
> user/bsps/arm/beagle.rst | 6 +++---
> 1 file changed, 3 insertions(+), 3 deletions(-)
> diff --git a/user/bsps/arm/beagle.rst b/user/bsps/arm/beagle.rst
> index 87c6ecf..fe2dc6f 100644
> --- a/user/bsps/arm/beagle.rst
> +++ b/user/bsps/arm/beagle.rst
> @@ -61,9 +61,9 @@ Add the following to a file named uEnv.txt:
> I2C Driver
> -For registering the `/dev/i2c-0` device, a wrapper function is provided,
> -``bbb_register_i2c_0()`` similarly ``bbb_register_i2c_1()`` and
> -``bbb_register_i2c_2()`` are respectively used to register `i2c-1` and `i2c-2`.
> +The Beagle has the `i2c-0` device registered at initialization. For registering
> +`i2c-1` and `i2c-2` ``bbb_register_i2c_1()`` and
> +``bbb_register_i2c_2()`` wrapper functions are respectively used.
> For registering an I2C device with a custom path (say `/dev/i2c-3`) the
> function ``am335x_i2c_bus_register()`` has to be used.
