RSB do not build rtems-tools any more?
jameszxj jameszxj at gmail.com
Sun Sep 29 05:48:22 UTC 2019
I didn't notice any errors in commnad console. But you remind me, I search the log file , and I found the build  is successful, maybe the install dir is mistaken.I cut out some related log lines, the whole log is too big.
Thanks
------------------ Original ------------------
Date: Sun, Sep 29, 2019 12:20 PM
To: "jameszxj"<jameszxj at gmail.com>;
Cc: "devel"<devel at rtems.org>;
Subject: Re: RSB do not build rtems-tools any more?
On 29 Sep 2019, at 12:11 pm, jameszxj <jameszxj at gmail.com> wrote:
   I build from rtems-source-builder version(abbcc5d8c6b4de60f83aaece5a9f4feef4c251c9) on MSYS2,
command is "../source-builder/sb-set-builder --log=l-arm.txt --prefix=/opt/rtems/5.1 5/rtems-arm" but rtems-tools was not build.
Can you  please post an error log?
Thanks
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190929/13c66180/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190929/13c66180/attachment-0001.obj>
